Hi I'm a new to forum. My em6910 the pump runs on after the shot finishes, the water and pressure shuts off as normal and no matter what buttons are pressed it seems to run uncontrolled, to stop it you can only switch it off at the wall. hope someone can help me with this problem.......................... regards greg
EM6910 main pump running on after a shot finished problems
Originally posted by valkyt6 View PostHi Burr,, I have been waiting for the run on problem to surface again and it seems to discharge into the drip tray as it runs pass where the shot finishes , so can you give me an idea what the problem is.... regards greg
Almost certainly a jamming solenoid. When it cools down it frees up by itself (too common in all sorts of apps). It is "half switching" over to the cleaning cycle. Easy to identify the beast via the schematic from there.
If you are not mechanically minded, take it to a good repair shop. In WA, that means Coffee Classic in Hilton, even if another one is around the corner from me. Other states, try asking CS sponsors or browse a few CS threads.
TampIt
TampIt
