I own two EM6910s and have had them for several years. One at work and one at home.
The one at work produces magnificent textured milk, but no matter what pump rate and steam temp I use I cannot produce any decent frothed milk at home. It has never really been as good as the one at work and is a little older, but recently it has become worse so I decided to do something about it.
So I thought the steam pump must have had it and dismantled the machine and replaced the steam pump with a brand new unit, however the pressure is identical as before and the milk is still crap.
What else can I do? The coil of pipe above the steam pump looked very clean and I poked a length of wire in the ends anyway to see what would come out but the wire looked clean, but it wasn't flexible enough to go all the way through. I suppose there is the possibility it is blocked somehow, so maybe I should try a very flexible pipe cleaner after soaking the coiled pipe in descaler. Is there anything else I can check and/or replace?
Oh and one other problem this machine has is that it stays in standby mode (always hot) even when powered off (no Power LED flashing at all). The only way I can stop it from staying hot 24/7 is to turn it off at the power point. What can I replace to fix that?
Thanks,
Ben
Thanks,
Ben
