HX machine problems- Brugnetti
  • #16
    Originally posted by MrJack View Post
    Sounds like you might be describing an anti-vacuum valve?
    Thank you MrJack. Now you say it, that is exactly what it would be.
    • #17
      They usually have an o-ring for the seal. It can perish/go hard. You could replace the o-ring (bearing shop) or the entire valve from one of the sponsors. They are not expensive.
      • #18
        Thanks Artman. My o-ring looked ok so I left it in place and my anti-vac valve is all good after my work with the wet and dry. I guess my point was that if the pump is running often then it could be an indication that water or steam is escaping the boiler. It may then be worth examining the machine to see if this is the case and where.
