Originally posted by Debs6
View Post
You are welcome.
I just noticed you are in Mandurah (just down the road from here).
Scales: IMO they save more than their cost when time is spent running around in circles with cantankerous gear. I know Grand Central @ Bibra lake handle the two models of Bonavita scales which are designed for coffee. Bonavita probably have competitors, although my original set is still going after well over 20 years... and they have always measured consistently, as do my new ones. Some of the cheapies give a different reading every time you use them (even the so-called 0.01g ones), which kinda defeats the purpose.
Dosing: The 4mm should be close enough as a beginning, however experiment away.
Naked p/f to suit 6910 tends to be around $80 to $100, or if you can access a lathe it is about a 5 minute job (safety note: cut the centre out from the INSIDE). Also, in the meantime, remove that dreadful piece of plastic inside the p/f with a pair of needlenosed pliers after removing the spout: you may be surprised what you find under it! Feel free to PM me if you need more details, just don't expect a quick reply these days (massively over occupied for the next few months).
Have fun
TampIt
