I recently bought a La Pavoni Professional Pre-Millenium model and have a couple of questions for those in the know.
What sort of dosage weight do you put in the double basket??? After alot of reading I realise this is approximate as people use different weights for different beans/roast etc....Just after a good starting point to then experiment from there as I've read anywhere from 12-14g.
Also what should the pressure cut off at as I have noticed it will cut off then drop in pressure. An example would be it cuts off at 0.9 bar and then will drop to 0.75-0.8.
What pressure do I want to be pulling the shot at????? Should it be where pressure stops or where it drops to????
Any advice would be much appreciated.
