Hi,
I am using above stated espresso maker. I live in West Japan (60Hz 100v) and was in touch with the Breville support lately as the machine is acting up. Basically I am having the same problem as the guy in this video:
https://www.youtube.com/watch?v=4OjlMqK4bEY
I hope someone could help me with a few questions:
Is there a problem running the machine at 100v 60 Hz instead of the 120v 60 Hz in the States? The Breville guy said it might even shortcircuit or burn the machine out. To my understanding of electrics lower voltage will interfere with the heat up and might irritate the timers. But under no circumstances it could break the machine... Any electricians here?
The machine was working quite well initially but since we pull a lot more shots (about ten per day) it seems to break increasingly. Problems are:
It would be great if someone could give me advice on what to look out for. I am planning on opening the machine on Monday/Tuesday. I think the grinder is difficult to analyze but help with the pump/OPV would be appreciated!
Is it possible to replace the Ulka pump in the machine with a better pump, as I believe the pump is currently causing most of the issues (also stated by the guy in the video above (read the video description). I saw that there are also 100v models of Ulka pumps out there. Would it be better to get a 100v one? Or should I get a step up Transformer?
I am planning to switch to a Rocket Espresso Maker soon (this is not a question, just a statement since probably a lot of people will say I should just ditch the Breville
Thanks,
Daniel
- Loud pump at times (it seems to run empty and need to refill first),
- OPV working unreliably (after steaming the water is way too hot),
- no pressure build up (sometimes good, sometimes bad...),
- unreliable grind amounts (this is weird as it seems the more you grind in a short amount of time the more ground you'll get...), etc.
Thanks,
Daniel
