EM7000 settings
  • EM7000 settings
    My EM6910 has started to develop strange symptoms - a very nasty sound for the first pour most days, erratic steam behavior, and leakage of clear water from around the filter basket. Therefore, since the EM7000 is now available for $399 (clearance) I bought one. I have had my EM6910 for so long that I do not remember any settings I changed from factory default.
    So, are there any recommendations for changes to the default settings? I use the machine for milk drinks but also for straight espressos; always pouring double shots.
    I suggest leave it at factory until you sort the new Grind/Dose/Tamp process and then look at changing settings. The machine is different enough from the EM6910 to assume the old settings are not suited to the new machine.
      If you overfill the basket, then it will leak water from the basket.
      See my post in here http://coffeesnobs.com.au/brewing-eq...-question.html
