My Parents have a lelit combi, badged as a Quaha Napolitana. It has been going strong for close to 20 years making a couple of coffees a day.
Just recently it has started behaving like there was not enough pressure to push the water through the coffee, no matter how lightly it was tamped or coarsely it was ground. I suspected the Pump, but before i pulled the machine apart I thought i had better check the OPV valve. Sure enough when i went to make a coffee, after I had switched on the pump, i opened up the water reservoir and found the water pouring out of the OPV discharge tube. So I am guessing the pump is fine but the OPV needs replacing. Does anyone see any flaws in my logic so far?
So my question to the greater snob community is, is this a normal thing? do these Valves fail? is it a case of just pulling it out and giving it a clean or is it not worth bothering with and i should just replace it?
I must admit i was quite chuffed that i could diagnose the OPV just by looking and hearing a description. (if indeed that is the problem)
