Get rid of ECM giotto? Help!
  • saywhat
    Hi guys, didn't mean to cause such a fuss.
    My apologies to charlie and others if my comment re:jetblack was poor form, I was simply describing my experience with them. I will speak with charlie.
    Re: all the other suggestions. Thanks! I was hoping to be critiqued in the video so that's great.
    I've ditched the VST as I thought it better to concentrate on getting it right with stock baskets first.
    I weigh the beans on a scale and then grind. I think there was 17 grams in that shot.
    What would you suggest to improve dosage and distribution?
    I'm just a newb guys so any constructive criticism is welcome.
  • Steve82
    Originally posted by saoye View Post
    Personally I would grind a little finer and tamp lighter but your crema from what I could see was fine. Next time do it into a shot glass to see how much crema.
    THIS.
    You are still using 15g VST? In my experience a bit more finicky than the 18 / 20g variants.
    Using a slightly lighter roast, grind finer and actually make sure your dose is bang on 15g, or grind even finer and and try 14 to 14.5g.
    VST hates overdose = channeling.
    As said above you need to work on your distribution.
    I will go out on a limb and say where you are currently at in your journey if you are still using the 15g VST? you will be better off getting some EP precision baskets or synesso baskets and learning to dose those consistently by eye or weight. Then return to VSTs when you are in a good place.
  • chokkidog
    Originally posted by Talk_Coffee View Post
    • Massive cooling flush- not required. It why you had a restrictor fitted
    • No consistency whatsoever in dose method, average distribution at best and firm polish. I'd suspect that the use of a naked would show significant channelling.
    • Five Senses coffee- probably very light roast. Not a personal favourite, but horses for courses. You will need a much tighter pour to get much from it.
    In conclusion, I suspect that the tradie is blaming the tools....It's time for some quality training.
    Agreed Chris.
    If that was a 220ml or so cup then that is a significant injection of cold water into your boiler just before you pull the shot.
    Coffee will be thinner and more sour the cooler you go.
  • chokkidog
    Originally posted by saywhat View Post
    Also, I am having trouble getting the thick suspended in the air honey type espresso. If when I extract it runs fast I grind finer and it just seems to restrict the flow more instead of thicken up. I've been endlessly playing with dosage and grind settings but doesn't seem to help.
    Five senses beans roasted a week ago but I've had real trouble pulling a decent shot.
    Were you getting um.."thick suspended in the air honey type espresso" with the same bean, on your previous machine?
    Body relates to roast and roast age as well as bean/blend. The crema looks quite pale, was the shot sour?
    Agree with the above two posts re going public.
    Being on the other end of the relationship, I feel for Charlie.
    Best option is face to face. If not a phone call. It's in the interest of all sponsors to get it right because CS members are a proportion of our marketing team.
    It's a shame when an issue is taken to an open forum first.
    Edit:
    Having watched the video:
  • Yelta
    Naming a company as being a poor service provider in an open forum is very poor form, the appropriate action would have been to take it up with them via a phone call or PM.
  • JetBlack_Espresso
    So here's an update. Thanks for all the suggestions so far.
    Got the machine back from jetblack and got them to do a calibration on it as it worked fine with them (I must have tripped something when working on it).
    As a side note I was really disappointed with their service. I was quite surprised by this especially with the rave reviews here.
    I'm sorry to hear that saywhat. I'd like to follow that up with you - PM sent.
    charlie
  • saywhat
    Yeah I certainly won't go back to jetblack. I will use a shot glass next time, I need to get another one. Thanks for the help saoye.
  • saoye
  • Lukemc
    I too have been disappointed with their service twice, they won't get a third time. It's a shame. Coffeeparts is in sydney too as well as dibartoli. Both have been great in the past if you need something next time try one of them.
  • saywhat
    Ok cool. I took that video when I first got the machine back so was still treating it like it was running hot.
    I now give it a real quick flush and then go. Is it kind of like a tuned hx now? ie ECM technika
    The crema dissipated very quickly on that shot. But things have improved since that video as I have a better feel for the machine now.
    Just wanted to see if there was anything majorly out with my method too.
  • saoye
    So what was wrong with the shot? Why did you need that massive cooling flush? If you want to judge an espresso shot would be better in an espresso glass.
    The restrictor basically restrict the circulation of the super heated water in the e61 brew head so it doesn't get too hot and therefore no need for the cooling flush
  • saywhat
    So the machine is fitted with a restrictor now so that brew temp is 95C.
    How does this affect the cooling flush? I have been flushing a small amount, about the same amount for a double.
    I must say it has been a bigger learning curve than I expected going from the sunbeam to the giotto.
    Here's a video of a shot I uploaded when I first got it back. Five senses beans roasted a week ago but I've had real trouble pulling a decent shot.
    http://youtu.be/YUfuZA0fC3c
  • KiwiMike
    As previously mentioned with my experience with my ECM Giotto I would strongly suggest that you ONLY use CS recommended repair/service companies, there are too many monkeys out there unfortunately in my case the work had to be redone plus some items weren't serviced at all !
  • saywhat
    On site service sounds good especially if I have to travel that far. Has anyone used auspresso? They are in parramatta which is a bit closer and also repair machines.
