Hi CS
My trusty Classic, which has been with me for many many years and many road trips (it goes everywhere) finally died this morning. Half way through pulling a shot the pump stopped making its usual viby noise and turned into a much quieter and deeper sound and the coffee stopped pouring out. i flicked it to steam mode and hit the pump. it made the same low noise and no water comes out of the steam wand either. now this is different to the other issues i see on youtube where the pump makes a really high pitched scream. ive had that issue but that's just a block/water thing and can be fixed by leaving the machine cool. to me this sounds like the pump has finally died a slow death and is no longer pumping. like i say it still makes "the noise" but its very different to the normal pump noise. it's as if you've taken your foot off the throttle and the engine is now at 500RPM instead of 1500RPM. Not sure that helps but you get the idea. so before i buy a pump for about $60 I thought I would ask the pros if I'm on the right track with the pump OR could it be something else and the pump is just a symptom. with no water coming out of the group or wand and the pump making the same exact low noise on both with no pressure involved you would think pump but maybe a solonoid is blocking the whole thing or??? \
thanks all. i can post a video if that helps???
Video on the way....
