Hi all.
So I went ahead and bought the Combi from Lelit a little while back and it worked great for a little while. Now, I can't pull a shot with it, without it leaking all around the grouphead.
The Problem
When pulling a shot, the gauge will get up to about 8 bars and then there will be a leak around the grouphead (sometimes immediately on pressure building other times after the shot has just started), spraying water and coffee everywhere, losing pressure, and forcing me to abandon it all.
What I have tried
Increase/decrease tamp pressure;
Experiment with grind coarseness (I will note that I do get a shot out of a very coarse grind, at about 2 bars of pressure, which is watery and completely underextracted)
Experiment with whether a shorter/longer warm up time is the issue.
Test different levels of fullness in the basket
Backflushed - although it replicates the issue well and truly before the pressure builds up.
Took it back to the supplier for repair - although they couldn't find anything wrong on first viewing, it then replicated the issue when I went to pick it up, and then the group head, seal, shower and handle were all replaced - yet the problem remains.
The issue continues though, I worried it was user error, however I have been using both commercial and domestic machines for over 10 years and while not a pro, I know the mistakes that I can make and how to rectify these issues.
So, has anyone else had any of these issues with a Lelit, and are there any solutions that I may not have tried as yet?
Cameron
The Problem
What I have tried
Cameron
