Hello,
I've gotten a lot of tips out of CS over the years so I thought I would sign up just to post this little tip.
The chrome paintjob on the (plastic) shroud/cover that goes over the group head on my Siliva V2 had started to peel and crack badly.
Instead of paying $40+ for a replacement, I just sanded and then painted mine matte black. I used special 'high heat' paint which cost $17/can at Masters.
The peeling was pretty bad:
The paint I used:
After 15 minutes sanding (starting with 240, finishing with 800):
A number of coats was required, though I didn't use primer. The material seems to soak up the paint and it touch dries in minutes.
I kept doing coats and giving it a light sand with 800 grit paper every now and again until I was satisfied, probably 10+ quick coats.
I think the results look great, I probably prefer it to stock. The finish matches the steam knob pretty well.
The paint I used:
