Hi CS'ers,
I recently scored a Gran Romantica on evil bay. To put it nicely, we are not friends yet. The unit leaks at the gasket between the boiler and group handle if I use too much pressure when pulling the shot. Does this mean my grind is too fine or my tamp is too hard? Or does it simply mean the machine needs a service? The joint immediately seals up on release of the handle so I think the gasket is fine.
I have read all of Pavoniboy's posts and feel that I am doing everything correctly but I'm just not there yet.
Also, what size tamper do I need to buy? I'm still using the plastic one that came with the unit. I would normally get out the verniers but it seems the baskets are slightly tapered.
Thanks in advance.
Thanks in advance.
