You only need a new boiler element and o-ring.
The distributor should have them
Grimac Boiler not heating
So a skilled technician looked it it. Boiler is leaking from bottom and element is stuck open circuit.
Any idea where to source a boiler from????
Yeah I wouldn't attempt myself, have a contact who is very skilled with it so wanted to pass the info onto him. Not my line of work that's for sure!
Hi Matt,Originally posted by Matt4007 View PostThanks. Are there any guides online for it? I wouldn't even know what part of te machine I should be looking at.
Might I suggest that this is a job for a qualified technician. 240V has produced many recipients of Darwin awards. If you don't know what you're doing, don't do it.
Pressurestat or element control relay most likely. You can replace the pressurestat microswitch with a Cherry D45X. These can be bought on RS Components for a few dollars. You will also need a T10 torx driver to remove the switch from the pressurestat.
Ensure the machine is unplugged from the wall.
If no luck, take it to a technician as any further diagnostics/repair would be best left to a qualified person.
Grimac La Uno manual machine
Havent had any dramas with the machine before
Now today the boiler wont heat up
The pump still works and the water is coming through the screen, jut not hot.
The light at the front comes on then turns off quickly and no pressure is registering on the gauge at the front
Whats the first steps to diagnose the problem?? Not really that handy when it comes to machines
Thanks for any help!!Tags: None
