This is my first post, sorry if similar questions have already been answered and such I just want to know whether I'm on the right track my recently acquired units.
I got a second hand em6910 and em0480 (nearly two years old) today. I'm pretty much a coffee noob but wanted to get an entry level set up for not too much.
Normally I would have wanted to trial/inspect the machines before taking them home but because they were from out of town and only in my city for the day and because the price was really good I decided to take a gamble and purchase without being able to try it out.
The previous owner said the group seal is on the way out and needs to be replaced therefore the level of coffee needs to be a bit lower otherwise it will leak which I was fine with if it only needed a new seal.
Tried out the machine and found it to be leaking moderately from the underside with the double shot dual filter basket. I then tried it without the coffee with the same basket but empty and it still leaks.
It doesn't leak so much with the single floor baskets but the shots were gross, I'm aware the dual floor baskets are the way to go?
I read on another thread however that the seal rarely needs replacing implying the seal may not be the main cause of the leaking.
I've ordered the seal on ebay and will install the new one and clean the shower screen. If that doesn't work I might try the DIY cardboard spacer under the seal trick (I wonder how thick the spacer should be?).
If I still have no luck I might have to try changing the collar as it looks a bit worn but I'm not really sure. I don't know what'll be the plan after that as I would rather try to deal with it best I can myself.
As for the em0480 the grind is coming out super coarse for all the settings. Doesn't seem to change in coarseness at all.
I plan on taking out the burr and giving it a good clean and placing one or two extra shims under the burr as advised on another thread.
Not having much luck but hopefully it all comes together? I do enjoy a challenge but I'm just hoping I'm not wasting my time/money like an idiot :/
Thanks for any help/advice
