Folks,
I've recently taken receipt of the below gear and am having some minor issues - would greatly welcome feedback or thoughts (my sincere thanks in advance):
Here's the critical info:
Espresso Machine: Rancilio Silvia V3 (bought ~2012 from DiBartoli) - in very good condition, new silicon group seal.
Basket: Stock Rancilio 40-100-102 basket
Grinder: Compak K3 Touch (has brand new burrs in it ~2kg or less through them!)
Tamp: CleanMachine/ProTamp 58mm
Coffee: CS sourced home roasted (within week of roasting)
Dose: 13-14g of grinds into basket
Problem:
Double shot extraction (have measured into labelled shot glasses) seems to consistantly come out far too rapidly. I have to terminate the shot at 10-15sec as it's clearly beginning to blonde badly. The resulting shot will be bitter (which thankfully is marginally hidden by drinking with milk BUT I know a lot better can be done). I reverse temp surf before I pull the shot, don't feel this is an issue in the problem.
Solutions already tried/thoughts:
GRIND..?
My first thought was that it was a 'grind size' issue. However, I'm at a VERY fine grindsize that I'd feel is closer to Turkish than traditional espresso size. The K3 is well regarded and as stated has brand new burrs in it, which I've checked and definitely are correctly aligned. I've taken it all the way to choking the machine and then backing off a tad but it's such a finely balanced point I feel this isn't the issue.
I've compared my grind size to a fellow CSer who has a La Spaz S1 Vivaldi II with a HG1 grinder and he's using a much coarser grind than myself (big difference). If it assists see below macro images of my grind with table salt etc for comparison. So if anything at present I feel my grind might be a bit finer than ideal for long term usage.
DOSE...?
With these stock 'improved' Rancilio baskets the common feedback is that a ~12g grind dose is pushing things (others feel this way?). So I've found that ~13g is about as much as I can put. When tamped (and I tend to err on the side of a lighter tamp) it bring it down to just under the internal ridge line. I'd previously had some issues with distribution but try and stir the grinds with a thin bamboo skewer and take my time in prepping the basket for the shot.
I've also got a couple of 17g La Mazocco ridged baskets, which I've bought as they were sold as being 'identical to VST baskets' though thats clearly NOT true. I know using a larger basket is often felt to assist with the Silvia's but if I can't extract properly from the stock basket I can't imagine a different one will magically cure it as there's likely other variables at play.
PRESSURE/FLOW..?
I secretly suspect this might be the issue as I've read several other threads of folks in an identical situation and often it was their OPV at a high level. The machine was originally bought from a CS sponsor, Di Bartoli - but when I contacted them today they weren't able to advise if the machine would have been calibrated prior to shipping out - as I wasn't the original purchaser and it was ~3yrs ago.
In a very inexact flow test I got 101g of water out through the portafilter in a 15sec extraction. Now apparently if you want to test the pump/OPV flow you're meant to use a blind filter and then measure the flow via the overflow tube instead....?
http://coffeesnobs.com.au/brewing-eq...out-gauge.html
Happy to try this as I suspect mine is running high so if folks can confirm this is safe to do. I should also flag that I live in a regional area with no CS sponsor etc nearby, nor access to a pressure gauge so perhaps this is the best way to check the OPV is not running far too high.
Thank you in advance for any feedback or assistance,
Nick
Problem:
GRIND..?
DOSE...?
PRESSURE/FLOW..?
Nick
