Replaced my brewhead seal two weeks ago.
Was running great, no leaks when all of a sudden: Leaks!
I ordered a new collar but then checked the seal and it has a gouge out of it. Not sure if the gouge is enough to let water through, but suspect it is and I should have just ordered another seal instead.
Thought I may as well replace the collar since it arrived this morning. Followed Wan's excellent guide but came unstuck when attempting to remove the Torx screws holding the collar. They all snapped on me!
At that point, I thought about drilling them out or buying a screw extractor, but realised I didnt have any replacement screws on hand, and the underlying feeling that I would go to a lot of effort to replace the collar, only to have it still leak due to the seal.
For now, I have tried to fill the gap in the seal to see if it is that, but suspect it wont hold until I get another seal.
I hope I don't have to buy a new seal every second week!
I find it quite hard to line up the portafilter handle. Often takes a few goes (seems to want to default to sitting at a 30 degree angle) until it is sitting flat and can be rotated into place. Does anyone else have that issue or have any tricks to help properly align it?
This is probably why there is now a chunk out of the brewhead seal. Guess I need to get another one and be very patient when trying to line up the portafilter handle.
