Hi All hope this is the right area to post in, I am a newbie to all this. I got my Saeco magic out of storage and had to get a new water container as someone broke it, and now the new one leaks, I have ordered a new seal , will see how that goes hopefully it will fix it, are there any tricks to this area. My other problem is the ground beans light is on and the machine won't go at all. I have it in bits and checked all the micro switches with the multimeter and all are working. The printed circuit board looks fine under magnification but thats as far as I have got. Could anyone give me directions as to where to look and what may need fixing. The machine has made about 100 cups max since new. Thanks in advance guys.
Saeco Magic Delux problems
- Dec 13
- 956
- Brisbane
- Bulk brew; Pour over; Double Ristretto; Oat Milk Cappuccino or Piccolo
- Send PM
Is the grinder full of old beans (whole and/ground); check the exit chute - they get blocked with grounds and no coffee can fill the brew unit piston chamber.
Ovets,
I've had a number of Saeco machines ,all similar to your magic and all refused to operate,just made a noise and stopped with red light on!!
Every single machine simply needed a full disassembly of the brew group assembly,clean and reassemble.
I have found Paw Paw cream (red container) a excellent lubricant for the brew part and as it's totally food safe ,safe to use anywhere.
The fact that it worked fine before being packed away would suggest it is something straight forward,hopefully.(good luck)
Mick.
Originally posted by mulquemi View PostI have found Paw Paw cream (red container) a excellent lubricant for the brew part
qsmart.net.au/msds_pdf/PetroleumJelly.pdf
Would be better to use genuine Food Grade lubricant (very sparingly) such as this one from one of our Site Sponsors...
Food grade silicon grease | Talk Coffee
Extract from manufacturer's page...
A quality product requires quality ingredients.
Carica Papaya 39mg/g Fresh Fermented Fruit
The papaya used in Lucas' Papaw Ointment is Queensland grown fresh fruit.
ingredients-1The fruit is received fresh to our factory in Brisbane where we ferment it under strictly controlled conditions. Every item of fruit we use is hand selected. Once the fruit is fermented to just the right level we can use it to make the ointment. The finished product contains 0.1mg/g of Potassium Sorbate which acts as a preservative.
divider-halfcontent
Base - Pharmaceutical Grade Petroleum Jelly and Wax
Our product does not contain polyplasdone, polyvinylpyrrolidone, talc, shellac, palm oil, glycerin or sodium lauryl sulphate.
ingredients-3The base used in Lucas' Papaw Ointment meets the purity and safety standards of the United States FDA and the European Pharmacopeia.
It is a pharmaceutical grade base that is tested and screened for the level of total polycyclic aromatic hydrocarbons. Penreco USP grade Petrolatums are not mutagenic or toxic to reproduction.
Every delivery we receive is certified to confirm its safety and quality.
divider-halfcontent
Gum Balsam Peru
A minute amount of Gum Balsam Peru is used as a perfume in Lucas' Papaw Ointment.
Thanks guys, I will be cautious with any lubricant, I read somewhere that the curcuit boards have problems is there any check I can look into to see? I rang Phillips trying to get info and they wanted me to send the whole machine to Qld then phone a guy in South Africa so I gave up on them its impossible to get direct info from them, seems you only get to talk to call center staff. If I could find info on what to check would be a bonus, any ideas there.
