Evening all,
So this morning I was doing one of the regular backflushes of my Silvia and I noticed the solenoid sticking (no dumping of cleaning liquid). Then suddenly the electrics cuts out for the circuit, and looks like the fuse got tripped.
After disconnecting the Silvia and resetting the CB I plugged it back in. I turned on the main power switch to the Silvia - all good. Then I turn on the brew switch, and the circuit trips again. I took the covers off, no apparent leaks or cable damage.
So at this point I figure its likely to be either the pump or the solenoid that is at fault here, given its only when they are powered that the circuit blows. Is there an easy way to identify which it might be that needs replacing?
