Hello coffee loving people,
Now I should be able to fault find this machine's problems however,I'm presently not in the ideal place to do that on this occasion.
This machine has arrived and it's 's history is this:
Machine would leak all over the bench when turned on,sorted!
Silicone hose to main pump was fractured just below the zip cable tie,I readjusted the bend of the hose and trimmed excess and re-secured the hose.
The main problem is machine will begin to heat up and then unexpectedly short out the circuit breaker.
At this point there is no water causing this short that I can identify,I wish to pick the collective brains as to what should I look at first,as possible reason?
I have another machine that will serve as components to exchange parts to eventually locate the source however,in an attempt to quickly locate the troublesome cause,what would the first suggestion be to check?
All helpful assistance is most appreciated,thank you.
Kind Regards,
Mick.
Kind Regards,
Mick.
