Best combined machine and grinder - midrange $
  • Best combined machine and grinder - midrange $
    Hi all - first-time poster but long-time reader!
    I've just given my folks my Rancilio Silvia & Rocky and am looking to replace this with an espresso machine with an integrated grinder.
    Hoping to get some advice on the best machine out of the following (I will mostly be making macchiatos, piccolos, and lattes):
    1. Lelit Combi with PID ($1249 from JetBlack Espresso)
    2. Isomac Maverick Plus ($1351 from New Coffee Italia)
    3. Ascaso iSteel with Grinder ($1199 from The Beanery)
    Thanks in advance!
    Rubyhill
    My vote would be with the Lelit machine every time....
    By far and away the best bang for buck machine around and very well built, easy to work on and easy to get parts for....
      Thanks Mal! I guess my follow on question would then be...
      Would you go for the Lelit Combi without PID for $999 or with PID for $1249? I've never had a machine with a PID before... is it worth the extra $250?
      Anybody else have any thoughts on the 3 machines I mentioned at the start of this thread?
      Thanks!
        G'day rubyhill...
        The PID Controller makes for a much more flexible and responsive machine and once you get a handle on the various coffees you like to drink, you can just 'dial-in' the optimum brew temperature for any particular coffee.
        The other real advantage of the PID Controller, is that it also controls the Boiler when in 'Steam Mode'. Set to about 125 Deg.C, it will ensure that you don't run out of plenty of great Dry Steam in the middle of texturing some milk.
        Whether you think that these advantages are worth the cost, may come down to a demonstration 'in person' if that can be arranged. The Non-PID Controller unit is no slouch either but it does require a bit more finesse in getting the most out of it. This holds true for pretty well any Dual Purpose Single Boiler machine though...
        All the best,
          The Breville BES870 is also a good combo machine. Can be picked up for $600-800.
          It uses a thermocoil rather than a boiler so much faster to heat up and switch to steam. Steam won't be as powerful but it's a well designed steam wand and is very easy to make quality microfoam, will just take a bit longer than a boiler machine.
          Obvious downside is the longevity; the Lelit will outlast it.
          However the older model, the BES860, is around 6 years old now and there's plenty out there still going strong.
          I think by the time it breaks down in a serious way you'll be looking to upgrade to a better machine and standalone grinder.
            Thanks so much Mal and noidle22! Much appreciated.
            I think I'll stick to the Lelit over the Breville, and will fork out for the PID option.
              You'll love the PID Lelit mate...
              Great home machine.
                Thanks in advance!
                Rubyhill
                Also keep in mind that options 1 and 3 come from Australian vendors that provide local support, warranty and of course machine supply. Option 2 ships directly from a guy overseas so you will be on your own
                Don't let the ".com.au" domain name and local phone number answered by a call service fool you. I know because we are regularly asked to pick up the pieces by customers who receive a faulty machine and who didn't realise they weren't dealing with an Australian company.
                charlie
                  charlie
                  Thanks Charlie for the heads up... good advice
                    ...I know because we are regularly asked to pick up the pieces by customers who receive a faulty machine and who didn't realise they weren't dealing with an Australian company.
                    charlie
                    Us too- and believe me we have picked them up. Literally- and not just once.
                    Lelit every time from your shortlist as far as I'm concerned Rubyhill. Charlie will look after you.
                      Thanks so much Talk_Coffee! Appreciate your opinion.
                      Another thumbs up for the Lelit makes my decision easy
                        I may be wrong (please correct me) but the thing that turned me off buying a Lelit instead of Silvia is that Lelit does not use a standard size group handle/baskets, unlike my Silvia. So my Silvia naked portafilter will not fit into Lelit and neither will my Synesso double basket.
                        I dont understand why Lelit produces a machine with non-standard group handle size, it wont cost them anything to use the industry standard sizes.
                        Bizarre.
                          You have a point with the baskets , although I believe some Lelit models have 58mm group? Portafilters are not generally interchangeable between machines anyway, except most E61 groups which should work together, but I understand there are some variations.
                          In terms of performance, nothing wrong with the 57mm group, mine is capable of ripper shots.
                            thanks.
                            So Lelit with 57mm group basket makes a better double espresso than Rancilio Silvia ?
                            I am wondering what to buy when my Silvia finally wears out.... Another new Silvia or something else?
                            I want reliability and I want a long lasting machine (5-10 years, no issues) which is why I would not consider Breville Double Boiler, even if it makes better double espresso than Silvia.....
                              Originally posted by acid_rider View Post
                              thanks.
                              Perhaps not better but just as capable. If your beans and technique is good both are capable of producing a ripper shot.
                              Mine (it's a Nemox but same as Lelit essentially) is 8 years old or so and is still going strong, no signs of giving up.
                              Lelit also gives option of factory PID if that's what you want.
