Not in the same class Magoo, the Isomac with E61 group head is a far better machine, unless your referring to thee Lelit Mara which also has an E61 group and priced around $2500, Lelit Mara (PL62)
$1000 budget beginner setup
Agreed. Completely different classOriginally posted by Yelta View PostNot in the same class Magoo, the Isomac with E61 group head is a far better machine, unless your referring to thee Lelit Mara which also has an E61 group and priced around $2500, Lelit Mara (PL62)
just a word of caution - Lelit single-boiler does not use industry standard portafiler/basket sizes unlike Silvia.Originally posted by Pauly404 View PostThe Lelit single boiler is a beauty. Same price as a Silvia but better looking and better build IMO.
This may or may not be important so I just mention it.
(beats me why Lelit decided to go alone re basket/portafiler sizes, looks like a stupid design to me).
The lelit 57mm group doesn't limit its ability to get great shots.
The only consideration is if you plan to upgrade at some stage to a "normal" 58mm group you could invest earlier in a quality basket/tamper and use it one your next machine.
Or keep the lelit as a back up!
Exactly. I'm currently using a Lelit 42TEMD while away on holiday and enjoying fantastic coffee with the whole gang (8 coffee drinkers). It's laughable that people will write off a machine based on one criteria - usually this type of statement will come from someone without experience of said machine and usually just regurgitating something written by someone else. Unless you have a specific reason to exclude a machine with a 57mm group head (eg your lucky tamper happens to be some other size) then excluding a machine based on the group head size alone is unnecessarily reducing your short list and possibly excluding the perfect machine for you situation. My situation (for this week at least) was needing a machine that made great coffee, didn't take up too much space and was relatively easy to transport.Originally posted by artman View PostThe lelit 57mm group doesn't limit its ability to get great shots.
charlie
Alright, I've got a Rancilio Silvia V3 lined up locally for $450, it has the KIT-RSPb PID fitted too which is nice. Now I just need to pick a grinder.. Thinking I might just pick up a Rocky unless someone can suggest a better alternative?
Well....as suggested above, a K3. Or a Macap M2M will do you better in the long run, and you should still come in at about the $1000 mark (less with a K3 I suspect).Originally posted by iMagoo View PostAlright, I've got a Rancilio Silvia V3 lined up locally for $450, it has the KIT-RSPb PID fitted too which is nice. Now I just need to pick a grinder.. Thinking I might just pick up a Rocky unless someone can suggest a better alternative?
