Just buy it! You'll be alright with it. Upgrade later when you know what you like and don't like about home espresso.
Would an 870 make good espresso?
Easy for us to say go ahead and buy it, we're not spending the cash.Originally posted by akinzin View PostYou guys do know how to make a man spend a lot of money.. It would be used by two people everyday.. Seems like the combi is the best choice, unless anyone objects? I know their is a whole separate grinder and machine thing that if one breaks and upgradability, but being in SA used machines don't pop-up often so this really is the best price (and I'm impatient and want one so bad). All in favor say eye!
If you can afford the combi go ahead, however if its going to cause financial stress perhaps the Breville will suffice in the interim until your better placed to upgrade.
I have a Breville BES920 and it's great. Not sure what all the histrionics are about.
I also have a VBM Replica single group commercial machine. It's even better and around 25 years old. Extraordinarily easy to maintain. A beautiful, classic design. And it makes sublime espresso.
Get the Breville, it'll last 5 years if kept clean and scale free.
And decide in a few years time if you want a 'better' machine.
I purchased an 870 5 weeks ago and at first had problems trying to obtain a good extraction even using the finest grind setting (extraction speed too fast, low indicated pressure and watery coffee).
Breville at first refused to exchange it when they found I wasn't using freshly roasted beans. This turned out to be a lame excuse although using freshly ground beans did improve things a small amount. Breville then sent a grinder 'shim kit' and I fitted one shim of 0.4mm thickness which improved things a little more. Last week I contacted them again for another reason and they sent two documents one being a test procedure for low pressure which I did and it failed the test. Breville then asked me to do a test overdosing the portafilter with the finest grind. They said the coffee should only drip out and the pressure gauge go to the end of the scale. The coffee dripped out extremely slowly but the pressure gauge only went up to about 3/4 and so they then agreed to exchange it.
I have only used the new machine once so far but already I have noticed that the grinder sounds very different and I am able to use a grind setting with a higher number (indicating a coarser grind but not really) and all without a shim.
It does IMHO it does make nice coffee and hopefully I will be happy with it for years to come.
There is a big learning curve for those who have never owned a manual coffee machine (finest of grind, correct dose, collapse and tamping and maybe adjusting the amount of extracted coffee from the default (this and also minor PID temperatures can be adjusted with this machine although annoyingly they revert to default factory settings if you turn the machine off at the power point).
I think that it is good value for money although if my budget was higher I would have purchased the model with the twin boilers or better still one of those professional looking machines made in Italy (over $2000). Only making 2 cups a day I really didn't want to spend more than I did.
Had mine for 2 years now, no problems with it and also took out the extended warranty.
However, I would not recommend this machine as you will grow out of it very quickly. Steaming is on the slow side, which is annoying as I drank mostly lattes. You will pull the odd decent espresso but are limited by the grinders lack of fine tuning. Hot water is certainly not hot enough to brew tea. Wouldn't purchase off ebay that's for sure. Pay the extra and go for the Lelit, I'd love one.
It sounds like you are in the price vicinity of a separate machine/grinder set up. why not look at a Gaggia classic or Silvia combined with a rocky grinder or similar? Even decent 2nd hand set ups can be bought for around the 1000 mark. That way in the future you can upgrade (or replace) each part as your taste develops or if you need cash you can always sell up! We've found that incremental purchases have landed us with a pro set up that hasn't impacted our finance all at once, therefore minimises any perceived hardship.
have a BES870 in the office which has been used/abused for the last 2.5+ years making 10+ coffees a day and still working properly. It was purchased due to the bench space constraint in the kitchen. It makes pretty good coffee IMHO and we're happy with it.
Yes it probably won't last 10 years, though it only costs 1/3 or 1/4 of the price of a HX machine. and its extremely easy to operate and takes minutes to heat up.
I would prefer to change the machine every 3-5 years as the technology now days changes faster than we can even think...who knows even after 2 years what more functionalities would arrive that would again lure us to buy another machine. I would not sink too much money in technology if I am going to get a good option in around half of price.
