Hey Guys,
Hoping you can help me out with this one.
I have a BES900 dual boiler and typically use the double shot button.
I have come to realise lately that the shot amounts seem to be more than they actually should be. They are at factory defaults.
I.e. single should be 30ml and double should be 60ml right?
When running it with no grinds, it will do
single: 55-62ml
Double: 78-85ml
I have tried changing the volume amount by going into the settings, putting the 60ml shot under, and pushing the button for when it gets to the right volume.
But the issue is when I put an actual extraction through it, it does about 20ml then just stops, like it stops at a timed amount instead of a volume amount.
Any ideas about this?
Actually I had not measured the single shot volume before, so I may just be able to start using the single button instead.
But would love some thoughts on this.
single: 55-62ml
Double: 78-85ml
