I just picked up a Breville BES860 for the princely sum of $5.
It was sitting in a trailer full of junk at a local garage sale, looking all forlorn and ready to go to the dump. The seller seemed rather amazed that I even wanted it.
When I got it home the 'Queen of Clean' attacked it with her cleaning gear and it came up looking like new. It appears to have had very little use and the burrs in the built-in grinder feel quite sharp.
Water in, beans in the grinder, power on and away it went.
Since I had only used some old beans to test it and, and perhaps more importantly, it only came with a pressurised double basket, I did not bother tasting the resulting brew.
I must admit that I was a little disappointed that there was nothing to fix so I had no excuse to look inside, but at least it will be interesting to see how it compares with the 6910 for making a coffee.
So now the task is to find a suitable non-pressurised double basket for it. A search of the CS forum only served to confuse me over the basket size and which machines might have a compatible basket(s). It seems the correct size is either 53 or 54mm and that most of the 8XX series Brevilles use this size so I would be pleased to hear from anyone who knows what will fit and what other brands may be compatible.
In the meantime I may get impatient and 'open up' the bottom of the pressurised one I have to see what happens.
Trev
Trev
. I am also guessing that the built-in grinder will need modding to get it to grind fine enough. Then the plastic fittings on the solenoid will probably crack - at least I will get to take the covers off. (Got to do something soon to cure this coffee machine addiction)
