Gaggia Classic, steam and gurgling during frothing. Normal?
Bugger. I didn't note the values before I changed them to default. I'll see if I notice any difference tomorrow when I brew.
Nah! Just make use of it. Do you remember the old PID settings before you changed them to Auber's default values? Just compare performance for brewing. Nothing to do with the steam function. The wild swing during steam function is not really a big deal.
Ahh so the thermocouple you are using is not RTD PT100. What you have is most likely a DIY. You have the option to lower the AH1 and AL1.
I went through and checked the values in the PID now that I have some instructions on the use of it. I have changed some of them back to the suggested default settings according to Auber. Settings shown below.
However this has not made any difference as the steam temp on the display still went up to 160 before dropping down again down to the mid-140's. As the settings for the steam were already at the suggested defaults then I guess I can only expect the same. I will try to lower these say 10 degrees and see how it goes.
P - 4.0 (changed)
I - 60 (changed)
d - 15 (changed)
SV - 102 (stayed the same)
AH1 - 148 (stayed the same)
AL1 - 149 (stayed the same)
Inty - 4 (I tried the suggested PT100 but it didn't show temp on the display anymore so I put it back to 4)
Corf - 0
That is how Auber Instruments designed the kit they made for Gaggia. The steam control is via the PID alarm and just an on/off electronic switch and the default setting is 149C off/148C on and you will learn soon enough how to best use it with some sort of temp surfing to ensure having dry steam to froth your milk. My most reliable technique is to open the steam wand by half a turn and turn the steam switch on. Upon reaching 120C, I close the wand and wait until the ready light turns on and I purge the steam until the ready light turns off indicating the heaters are active. When the temp reaches it's lowest downswing at around 141-142C, I start steaming my milk and I will get to my desired milk temp of 62C without the heaters turning off. I have weighed my steamed milk and the added weight is always around 10% compared to other techniques that I previously used that added as much as 17%. How much steam water do you add to your steamed milk?Originally posted by timmyjj21 View PostInteresting. You have steam control but only a single SSR? I don't have experience with the Auber, but all the DIY ones have one SSR for switching brew and one for steam.
Good luck with the tinkering of the PID settings. Keep us posted with your settings and experience with it.
Cool thanks for that JojoS. I will do some hunting around to see if I can find a manual to work out how to change the setting on the PID.
PM me your email address and I will share the Auber files with you from my Google Drive.
I just saw a 'how to replace a thermostat' video and it would appear that the wires are not connected to my steam thermostat as I can now recognize it within the spaghetti of wires. I guess this means my setup has a steam function. Now I just need to work out how to adjust the steam temp on the Auber.
Photos I just took.
Originally posted by JojoS View PostPop the top off and take a few pics of the inside and a pic of your PID controller/display unit. Maybe we can help you from there.
Do you have an Auber brand PID, or something else?
Edit- I'm too slow!
