So my EM7000 steam wand stopped Producing steam and now only water.
after some testing and research on here. i followed the advice below in the Quote.
The thermo block will heat up if just given straight 240v , so thats fine. the Thermal Fuse is fine, i have continuity through the fuse.
the Relay i replaced on the PCB was the one suggested in the post below, ( OJE-SS-112HM,000 | TE Connectivity SPST-NO PCB Mount Non-Latching Relay, 12V dc Coil, 10 A | TE Connectivity), also tested the solder was good , continuity from the new soldiered point to another point on the board in the circuit.
Steam Thermoblock still wont heat up, so I'm at a loss at what i could be. Any one have any idea's for what i could try.
Originally posted by noidle22
View Post
