The instructions say after switching on, open the steam/hot water knob, & pump in coffee mode till water comes out the nozzle. It's not clear if this means every time or just the first time (it does follow "remove the machine from its packing...").
I assume this is to clear any air out of the lines, but I would have thought pumping a little water through the group head before starting the heat up would do the job. I assume one or other of these should be done before the first shot of each day (and the latter between subsequent shots to help clear grounds on the screen).
