Hi everyone,
I've done a lot of searching and haven't quite found a solution to the problem I'm having with a 2nd hand 6910 that has come to me.
As soon as the machine has mains power, it constantly drains water through the overflow outlet into the drip tray. I've got the machine apart and checked for steam/water needles not being seated properly - not the issue.
I've inspected the PCB and can't see any clear faults with it. The triac drivers don't appear to be blown, but there is evidence of cockroaches having been in there and faeces is evident on both sides of the PCB. The machine is only a couple of months old. It does turn on and work fine, but I can't get the constant draining to stop.
I have a 2nd machine, the one I've been using for 8 years. It's problem is that once it heats up and turns on ready to use it makes a dull pumping sound and a small amount of water is discharged into the drip tray. It's not the end of the world but I would like to have one working machine.
So my question is whether anyone can help with either of these problems, and whether it's worth swapping the PCB from my old machine into the newer one?
Many thanks!
Luke
Many thanks!
Luke
