Nuova Simonelli Mac Cup S
  • pinoaraj
    Hi There,
    Saw your previous post about the work done on the Simonelli awesome , I would like to ask you a few questions apparently I got the same machine is working however is dirty , need some cosmetic work and I missing the water shaft , do you know which year is yours can't find any info , what you think about the machine quality is worth it to do the restauration? , I'm currently live in Chile move from California Sacramento 4 yrs ago ...Thanks for the awesome post ....Didn't find the way to upload the pictures, I can email you if want, to share some picture to see if you got more info about it ..Thanks
  • Sullo
    still going strong this one? I might have some questions!
  • fuzzyfozzy
    Thanks, yeah the Lil guy helped with all the setbacks. He is enjoying the fruits of his labour with hot chocolate's and baby Chino's.
  • LeroyC
    That's an impressive effort. I see you had some help though so can't take all the credit.
  • fuzzyfozzy
    Replaced every seal, oring, rubber feet and capacitor only thing still needed is a dual pressure gauge as it is not reading true. Refit resprayed pannels and polished stainless. Ohh and get round to plumbing it in.
  • fuzzyfozzy
    The machine is now temp set up over my sink while I dial it in and check over it for leaks.
  • fuzzyfozzy
    started a topic Nuova Simonelli Mac Cup S
    Hi, picked up the Mac cup a few weeks ago thinking the hardest thing would be running a new water point in my kitchen to plumb it in. Was I wrong..
    Machine had been sitting in storage for some time. After stripping down it was clear it needed some TLC. The only spots not covered in scale inside the boiler are where there is pitting and cracks in the heat exchanger tube. 😧
    Not admiting defeat, after descaling I drilled out the old tube souced some 40 mm type a Copper tube (3mm wall) from work. Salvaged the brass ends and silver soldered it all back together.
