2002 gaggia baby steam button
  • #16
    Ok thx level3ninja, appreciate your help..only wasted $5 ha maybe I'll keep trying source a genuine steam switch. Been looking but can't find 1 online. I've done the quote email to sponsors so hopefully will find 1
    Thx again
    • #17
      Unless someone with more specific knowledge than me can chime in, I'm just an electrician. Someone might only what those cables actually connect to in which case it might work. It does look like the two pink and two whites are in parallel but I don't want to risk the smoke getting out.
      • #18
        If you can go back to Jaycar take the old switch with you, and ask them for a "triple pole double throw" switch. They might have one.
        • #19
          Cheers buddy! Yeah I wasn't going to connect it without being sure, especially where I have zero knowledge! I'm just getting this machine right to take to UK for my coffee. I'd rather give up 5.5kg of my luggage & drink good coffee. Only paid $85. My bezzera is not going in any suitcase haha. Next I will buy & fit a rancillio steam arm & then it just needs a new steam knob as that has a small crack. Oh n a cheap grinder. Damn I have a coffee problem
          • #20
            Comments below are in reference to the first pic of your series of 3, post #14.
            I'm putting my money on the original being a double pole single throw with separate neon. It's a push button, correct? At a guess the two centre connections (one above the other) will be for the neon (hence the paralleled connections, to power it). The top left/bottom left are one set of contacts, and the top right/bottom right are another set of contacts. Each set of contacts ahould conduct when the button is depressed. So by your own numbering (post #12), 1 & 6 should be one set of contacts, 3 & 4 should be another set of contacts, and 2 & 5 should be the neon.
            Take the switch to Jaycar and confirm the left and right sets of contacts. The centre (neon) pair should not appear to connect to each other or anywhere else as a multimeter will not pick up the neon.
            Matt
            Edit: Most definitely the best course of action would be to just get the replacement original switch, no chance of getting it wrong then:-)
            Edit #2: Just worked out that when the button is depressed the neon wouldn't be on. Oh well, just buy the original switch and all will be good :-)
            • #21
              Thx for that. Yes original a push button with led light. Current wiring on old switch is from top right clockwise is top right white wire, middle right white wire, bottom right white wire, bottom left grey wire, middle left red wire & top left red wire.
              • #22
                Ok at the risk of getting myself into more hot water (as it were), a random Gaggia Classic diagram on the internet indicates the steam switch is a 2 pole switch, but with one set of contacts normally closed (pressing switch would disable solenoid and activate neon, would be terminals 1 & 6) and the other set is normally open (pressing switch would bypass/short HW thermostat, allowing steam thermostat to operate, would be terminals 3 & 4). Aaaaaand the neon would work as it should :-)
                • #23
                  Sorry for my lack of knowledge..I make great coffee but suck at electrics ha! So is the switch I bought DPDT ok or do I need the single throw
                  • #24
                    You would best going with the original. It could be done with a DPDT but would have to work it out. Do you have clear photos (edit: and part number) of the new switch you have?
                    You would also need to test the existing switch and confirm it is exactly as per post #22.
                    Matt.
                    • #25
                      Ok Cheers Matt, thx for your help.
                      • #26
                        Murray are you in Sydney? And how long until you leave for the UK?
                        • #27
                          Hey mate, I'm in Brisbane,
                          It's not urgent as don't leave until Sept so plenty of time.
                          • #28
                            Re Baby Gaggia
                            Originally posted by murray02 View Post
                            Hey mate, I'm in Brisbane, It's not urgent as don't leave until Sept so plenty of time.
                            G'day Murray, I've never seen a Baby G but have rebuilt/rewired a couple of Gaggia Classics and I have the gear to sort this out for you if you were able to bring it to me at Loganlea at a mutually suitable time.
                            PM me if that might be of help for you.
                            • #29
                              Hey thx buddy
                              That's very kind! I will see if I can locate the genuine button first as that will be the simple & quick thing to do.
                              But will let you know how I go. PM me an idea on price mate.
                              Thx again
                              BTW got a sunbeam em0450 off gumtree today for $15 never been used still in box ha! I'll fit a shim to it to make the grind finer. Not a great grinder but it will get me by. Not worth taking expensive machine/grinder just for a holiday
                              • #30
                                Hey thx buddy. That's very kind! I will see if I can locate the genuine button first as that will be the simple & quick thing to do.But will let you know how I go. PM me an idea on price mate. Thx again Cheers.
                                No charge Murray - it would be as a favour from one CS to another. I'm retired, and fixing/restoring coffee machines is one of my hobbies.
