EM6910 - Corroded Elbow Fitting
  • dukbilt
    Hi Justin,
    I've sent you a message - let me know if you have received it.
    dukbilt
  • justin
    I take delivery of a new Silvia tomorrow and have a broken EM6910 sitting on the kitchen bench. Where are you located?
  • artman
    Try Pirtek or Enzed (if sunbeam don't supply) or keep eye out for a broken machine you can strip for parts.
  • dukbilt
    started a topic EM6910 - Corroded Elbow Fitting
    Hello everyone,
    this is my first 'proper' post, so here goes...
    I have a Sunbeam EM6910 that has a badly corroded brass elbow. Its part number is C23-8009 and comprises a compression fitting for a 4mm outer diameter pipe on one end (M8 compression nut with 1.0mm thread) and a compression fitting for a 5mm pipe on the other (M10 compression nut with 1.0mm thread). This makes it an 'unequal elbow'.
    Can anyone offer suggestions as to where I can find such a beast?
    Thank you,
    dukbilt
