Retired my BES 920 for the EM7000.
  • #16
    Originally posted by TampIt View Post
    G'day again Tenfoot / Crema_Lad
    One quick point - I had my 7000 on 8 hour standby. The area near the steam thermostat just keeps on picking up heat because the "nice silent" 7000 is too insulated on the four I have now checked. Given a bit of hindsight, the fast warmup of a 6910 / 7000 means that the longer standby times are probably unnecessary.
    Btw - when you first warm (i.e. at circa the 90 second mark when the lights come on) a 6910 / 7000 it is essential to pull a few seconds of "post preinfusion" preflush to get the whole system (esp the p/f) at a constant temperature before a decent cuppa may emerge. After the series of shots, a quick post flush keeps the showerscreens so much cleaner... YMMV
    TampIt
    Thanks again Tamplt. I have utilised all of your excellent advice and am very happy with my tasty morning beverage
    Cheers.
    • #17
      Originally posted by level3ninja View Post
      I've heard the steam temperature gauge on the 7000 is only a timer, not actually temperature sensing. Can anyone confirm?
      No, it is definitely not JUST a timer, but there is something perculiar about how it does it's measurement, and time may be part of it's programmed calibration.
      I just ran a test with a very small and very large milk jug and a secondary thermometre. In both cases, the temperature wand exactly tracked the secondary thermometer, even though the large jug took twice as long as the small jug, and the machine obviously has no way of knowing what size jug I am using. This would indicate that it is indeed meausring temperature. However, the peculiarity is that if you start with hot milk, the wand never gets an accurate reading, suggesting that time is at least a part of it's measurement and calibration.
      • #18
        Originally posted by Brissienew View Post
        I am on the opposite journey, had the 7000 for 3 years, now has a 920 for a year. I find that the 920 makes better coffee, and produces significantly more powerful steam than the 7000. Perhaps there was something wrong with your steam wand.
        The only thing i like more on the Sunbeam is the temperature gauge for the steam, and its single basket is better than the equivalent in the Breville.
        There could well have been a problem. I never considered that could be the case as many of the early reviews of the 900/920 stated that the steam was more than adequate, though not outstanding. Pretty much how I found it. Perhaps there has been improvements in one or other of the machines?
        I can't really say that I got better coffees out of either machine. I was very happy with the 920's brew and am just as happy with the 7000. As a latte drinker, I saw a massive jump going from a single to dual boiler. I cant honestly qualify any measurable difference in brew quality between dual thermoblock and dual boiler.
        I am also conscious of the fact that it is easy to come to the conclusion that the newest is the best. We are after all comparing our new shiny toy with a jaded old one
        Glad to hear you are happy with your machine!
        • #19
          New is always good!
          I agree, I'm quite happy with steam output of bes920 but wouldn't say it's super strong. I was using a VBM Domobar at one stage and that thing could sure pump out some steam !!
          • #20
            Originally posted by Crema_Lad View Post
            New is always good!
            Yes, although I was quite happy with the performance of the 7000, I kept having issues with a leaky steam wand. It was probably just a seal or something that needed to be replaced, but I eventually managed to get a cash payout from my extended warranty and used that money to buy a new BES 920 when it was on special. In the end it cost me just about nothing to 'upgrade' to a 920.
            • #21
              Well done! I wish all upgrade paths worked like that
              sounds like the extended warranty worked well for you, I've always been a but skeptical thinking they are just a money grab by the retailer offering them.
              • #22
                IMO, coffee machines have a high chance of breaking down within a few years so it is worth getting the extended warranty. My EM7000 developed a problem with the steam wand being slow to shut off. It took them a month to fix even though it may had been a simple fix. Same problem recurred a few months later. I didn't bother getting it fix initially as I didn't want to be without my machine and had to resort to using my back up Nespresso machine. Eventually I got sick of the problem, and then I saw the Bes 920 on sale for cheap. I had the option of getting a replacement machine or having it fixed again. I thought I would try my luck with asking to be paid out rather than getting a replacement em7000. Much to my surprise they agreed! So I got lucky.
                • #23
                  G'day level3ninja
                  The temp sensor is on the wand. That means that you will only get consistent readings IF your technique is consistent. Holding the wand completely out of the milk will still give an increase in the temp reading.
                  FWIW, I can vary the temp readings quite a lot by varying the angles and depth of the wand. That is one of the things I meant with my earlier comments about steaming with a 7000:-
                  http://coffeesnobs.com.au/brewing-eq...tml#post608809
                  "To my mind the 7000 is a typical half assed automatic - if you don't know how to make coffee they will give you something "more or less" drinkable (even more so with the "auto steam wand" - grrrrr...). The more you know the more the 7000 gets in the way. I did tame mine (a domestic imperative based purely on noise level), however even after 2+ "7000 years" every time I go back to my La Pav 2 group or anyones 6910 I smile. Says it all really."
                  I would only add after the La Pav "also any LM, or Electra, or La Cimbali or ...."
                  TampIt
                  • #24
                    A quick point here - using some rather unfathomable logic*, SB usually adjusts the control pin for the steam knob on a 7000 so it doesn't shut off instantly. The one on mine annoyed me once too often, luckily after I had thought it through a little. Mine now shuts off instantly and then purges a little bit of low pressure steam 2 or 3 seconds after the steam is shut off. That helps keep crap out of the steam wand (even if I get a bit slack - hopefully rarely). If SB set theirs up like that on both the 6910 and the 7000 it would be a seriously smart move...
                    One of the 6910's potential failings: poor steaming technique (as demonstrated so brilliantly in their own 6910 DVD) = totally clogged steam wand. Some of the worst ones I have seen needed fairly serious chemical surgery to clear the encrusted milk out - the crap went "up around the bend". Nothing is truly idiot proof.
                    TampIt
                    *Unfathomable logic: Myself and a good friend originally suggested the following technique to deal with the stress when having to change the spark plugs on an early Toyota Tarago (for those who don't know - first you drop the engine out to access the plugs... almost as stupid as the BMW with the battery in the boot, what else did they think would happen?). If you added enough LSD to your coffee and balanced it with Valium it would help you comprehend the logic. If not, at least the stupidity would not depress you too much.
                    • #25
                      Having read the above posts it seems obvious to buy these Breville and Sunbeam consumer convenience machines with extended warranty as I did when replacing my three year old Bes870 with another one. But remember the extended warranty has an exclusion if you do not "maintain any servicing on your Product that may be described in the manufacturer's instructions ". As quoted from my Harvey Norman extended warranty document.
