Rancilio Silvia thermostat issues - keeps heating up!
Mine is a V3 and has the welded element. I think the V4 went back to a screwed element which is the same as the V5, using a Stainless Steel tube element outer shell.Originally posted by DenisGuy View PostMy machine is a V3 which means that the heating element isn't welded in the boiler.
The V3 element copper tube outer shells were prone to becoming brittle due to excessive heat. Incorrect priming procedures when steaming which exposed the upper portion of the element to air for prolonged periods at high temperatures was the main problem. Priming the boiler at power-on and especially straight after steaming as well as not leaving the steam switch on any longer than required all helps avoid this issue. I was also told that over-use of descaler can cause the copper to become brittle. I don't know if the Stainless Steel outer shell elements had similar vulnerabilities.
PS By the way did you use thermal paste between the new thermostats and boiler shell when you replaced the thermostats?
For your reference:
http://www.frcndigital.com/coffee/Si...lviaWorks.html
http://www.frcndigital.com/coffee/silviawire.htmlLast edited by CafeLotta; 11 February 2018, 02:28 PM.
Thanks for this. My machine is a V3 which means that the heating element isn't welded in the boiler. I've ordered a new heating element. I'll post again when I have an update.Originally posted by CafeLotta View PostWhen I bought my Silvia 2nd hand it heated up to brew temp fine but would trip the RCD/Safety Switch after about 20 secs with the steam switch on. Apparently the Silvia boilers with the welded in elements were prone to fractures/micro fractures near where the element joins the boiler shell if the boiler wasn't kept primed. The fractures exposed the live internal element part to water in the boiler making the boiler and adjoining metal parts live. The extra temperature heating up to steam was probably either opening up the micro fractures or raising the water level to reach them or both. Regardless, replacing the boiler/element fixed my specific problem.
In your case, overheating (maybe repeated over time) on a not fully primed boiler may have damaged the element before the 165 deg safety thermostat tripped. When you reset it after replacing the brew and steam thermostats, the possibly already damaged element may have been shorting creating the scenario in the links I provided.
Be aware that if you don't have the machine plugged in to an RCD/Safety Switch protected circuit you may electrocute yourself if you're not sure what you're doing.
When I bought my Silvia 2nd hand it heated up to brew temp fine but would trip the RCD/Safety Switch after about 20 secs with the steam switch on. Apparently the Silvia boilers with the welded in elements were prone to fractures/micro fractures near where the element joins the boiler shell if the boiler wasn't kept primed. The fractures exposed the live internal element part to water in the boiler making the boiler and adjoining metal parts live. The extra temperature heating up to steam was probably either opening up the micro fractures or raising the water level to reach them or both. Regardless, replacing the boiler/element fixed my specific problem.Originally posted by DenisGuy View PostThanks, I read both, but since it was working fine before I tripped the boiler fuse the first time around, I don't see how either can apply to me...
In your case, overheating (maybe repeated over time) on a not fully primed boiler may have damaged the element before the 165 deg safety thermostat tripped. Water level plays a part here. When you reset it after replacing the brew and steam thermostats, the possibly already damaged element may have been shorting creating the scenario in the links I provided.
Be aware that if you don't have the machine plugged in to an RCD/Safety Switch protected circuit you may electrocute yourself if you're not sure what you're doing.Last edited by CafeLotta; 11 February 2018, 02:35 PM.
Is it still overheating to the point of tripping the thermal cutout or does the light eventually turn off and the machine still function, albeit too hot?
It's possible that you indeed had a thermostat fault and upon installing the new thermostats, have accidentally installed two steam thermostats. Maybe whoever you bought the thermostats off accidentally sent two steam thermostats.
If you look at the writing on the side of them, it should indicate their temperature cutoff.
http://coffeesnobs.com.au/brewing-eq...eshooting.html
As above. The last post is very important too
Nice job caffe lotta
HELP! Rancilio Silvia overheating issue
This link you first read has pretty important info. Your machine may be very dangerous and live if the element has a new ground path.
Make sure its plugged into a tested rcd outlet. NOW! Or before you next turn it on..
Do they have dual elements? I dont think so.
Maybe the steam switch is stuffed, but if the thermal blew id say its getting even hotter than that.
So im sticking with brew thermostat...
How about this....
Your thermal fuse blew because it overheated. So you had a issue just before the thermal fuse blew and replacing tje thermal fuse has not resolved the initial overheating.
So the silvia is a single boiler (i think but not expert). So the part that turns the element off is the thermostat. Unplug them both and reconnect one then the other. Try using just the brew thermostat.
One of the thermostats sound to be stuffed. Probably the brew thermostat.
Hi, I tried to reply but apparently my reply disappeared...Originally posted by DenisGuy View PostIf it can help, I'd like to add that I hear a click when the water heats up that sounds, to me, like a thermostat going off, but the machine keeps heating. I'm not 100% convinced of that, though.
...I was saying that I did read these, and that I doubt that it could be useful to me because it was working perfectly before I had to reset the thermal fuse. Do you have any idea of what could be going on? Thank you
Thanks, I read both, but since it was working fine before I tripped the boiler fuse the first time around, I don't see how either can apply to me...Originally posted by CafeLotta View PostMay be worth a read.......................
Could it be something as simple as having left the steam switch on?
