Which option is better?
  • Which option is better?
    I'm using a LeLit Combi PID. Double basket holds 17-18g
    If 18g is choking am I better off using a slightly coarser grind or a slightly smaller amount to get the right flow in the right time?
    It's best to get the volume right first and then don't vary that. See/search for the 5c test. Then your only variable is grind coarseness. If you over/under dose your puck will hit the shower screen/be muddy.
