Water in the steam - LaCimbali Domus
  • Aaron
    In my experience with the Domus I recall that the steam pipe comes off the top of the boiler. In order to get too much water to run out of the steam outlet I think the boiler might be overfilled.
    if the water was too cold I wonder if it would be under enough pressure to be pushed out the steam pipe? Is your Domus the one with the autofill function?
    Can you hear the pump run while you are trying to stream?
  • Jackster
    Going to have to find the boiler pressure or temperature. But it sounds like its not hot enough
  • Fnerk
    Originally posted by bosco View Post
    Could be faulty steam thermo.
    Thanks - any other suggestions or fixes?
  • bosco
  • Fnerk
    Sorry, don't know. The machine doesn't have a gauge.
  • Jackster
    What is the boiler pressure?
  • Fnerk
    started a topic Water in the steam - LaCimbali Domus
    I've been using my LaCimbali Domus for at least 20 years.
    Today it has decided to add water to the steam coming out of the wand. I have descaled and cleaned, but it is still happening. This isn't just a bit when I first turn on the steam, it is continual, with plenty of steam as well.
    I would be appreciative of any suggestions of what might be going wrong here.
    Many thanks
