Upgrade? Side-grade? Modify? Thoughts....
  • #16
    I was in the same position as you exactly 1 year ago and it came down to a choice between the Bezzera BZ10 from Appliances Online and Breville Dual Boiler from The Goodguys.
    Both were available from Ebay with an additional Ebay20% discount so the BZ10 was about $1400 and DB was $720.
    I chose the DB and could not be happier, both have fast heat up times but there is extensive CoffeeSnobs support for the DB and half the price of BZ10.
    https://coffeesnobs.com.au/brewing-e...rs-thread.html
    Valvster
    • #17
      Valvster
      Thanks for the reply Valvster.
      I haven't looked at the Bezzera....will check it out.
      It's funny, I was very tempted by the Breville DB when it first launched. It was quite the machine for-the-money at that time. The features were pretty mind blowing
      I have zero doubt it makes great coffee, but I have always been suss about reliability of "those kind of plastic machines" y'know.....no offence intended, I am aware of my irrational snobbery. Can you get parts for them easily? Are they user serviceable?
      I forgot eBay discounts too.....I took advantage of it to buy my last phone actually. Maybe after xmas they'll have a big sale....
      • #18
        Originally posted by BrownMouth View Post
        I think it's an E61 from the photos ??
        Originally posted by coolie21 View Post
        The expobar office machines have a smaller footprint and probably better designed for home use. They are Hx E61 type.
        Neither of the machines referred to have E61 groupheads as far as I can see.
        • #19
          Which is why I said "E61 type"
          Its their own version of the E61 patent which AFAIK works in a very similar way.
          Nor sure why this minor detail would be a game changer for anyone choosing a machine?
          • #20
            No, they're not E-61 Groups...
            Still based on an original Faema design but there is no pre-infusion facility and the group exhaust is taken care of by a 3-Way Solenoid...
            • #21
              To clear up the confusion about the Breville DB, it uses a 58mm portafilter. I have been using a VST 18g basket and Pullman tamper with it for around 3 years. Parts are readily available and the pump is a standard Ulka, the 3-way valve is a standard one. If you feed them good water, clean them and descale regularly they will last quite a while. Much less than a fully metal equivalent, but you're paying around ¼ the price for the features. Coffee quality is as good as the beans and grinder you pair it with. I noticed a massive step up when I swapped the BCG820 for a Eureka Atom.
              • #22
                Thanks ninja.
                I have a few different pf's and baskets... so it's good to know I can use them if I go down the Breville road.
                • #23
                  You won't be able to use other portafilters, only ones designed for it, 58mm baskets no worries.
                  • #24
                    I think I've narrowed it down to 2 choices....
                    BDB vs Oscar II (used one in FS section)
                    This is a debate the snobs have seen before no doubt?
                    It's features vs horsepower,
                    Plastic vs chrome,
                    LCD vs semi-auto buttons,
                    Gentle steam vs The Tornado,
                    Australia vs Italy,
                    Innovation vs tradition....
                    Help me choose the one my wife will like the most! [emoji16]
                    • #25
                      Australia vs Italy,
                      The Breville is made in China - but the street the brand is named after is in Australia
                      • #26
                        Perfect!
                        And the Oscar is made by Simonelli.... and my name is Simon.
                        Is that a sign??
                        • #27
                          Plastic vs chrome,
                          Australia vs Italy,
                          Haha well put. 2 good choices
                          You could add "new v s/hand"
                          or even compare future second hand value of each model (Oscar would win this)
                          But we can't help you by telling you which is 'right' for you
                          Good luck!
                          • #28
                            BM and Tampit, you may want to chech that Tampit hasn't mistyped before you get any accessories based on this advice. Pretty sure this is a mistype and the Sunbeam and Breville take the same 58mm baskets as your Sylvia.
                            Thanks 338 for proofreading it better than I managed at the time.
                            Yep, it was late at night and TampIt didn't chech it well enough and had typoed the number badly - it is a standard commercial 58.4mm basket (just like every other one in my collection apart from a couple of 49mm Electra refugees). AFAIknow you cannot get VSTs in any other size.
                            Unfortunately it is too late to edit the size...
                            Enjoy your cuppa
                            TampIt
