Classic error with an EM6910 brew screen/filter. How to reassemble?
  • Classic error with an EM6910 brew screen/filter. How to reassemble?
    So I was descaling my EM6910, and removed the brew screen/filter (removed the screw and took off both screens and washer).
    However (and normally I'm extremely careful about this sort of thing), I can't recall what order the two screens and washer were in, or which way up each part should be.
    So now I have a lovely clean machine, but can't put it back together!
    Any help appreciated please.
    Install the flat screen into the seal first and then the washer onto the screen with the concave facing down. It should fit fairly well into the recess in the screen.
    The larger screen can now be installed into the seal.
    The whole assembly can be installed onto the machine. If you install it at an angle, seating the back of the seal first, the rest of the seal should slip easily into place. Make sure the small washer doesn't move out of place, you can just hold the screw in place in the hole to ensure it doesn't move.
      Ah, nice, that makes sense. Thankso so much!
