OK still leaning towards Victoria, but, it's a tough decision. Will think for a while longer and fill you guys in when I decide.
Thanks for the above posts was a BIG help.
Help with Machine Decision
I can drive to Jetblack, maybe 1.5 hours, but, I am so busy with work, and so tired when I am not working to put in the effort, I know that sounds lazy but that is how I am these days....
Another question.......E61 machines. Worthwhile for milk drinks? or best used for shots? Just trying to eliminate more options here. My beans (which I will start another thread about) come into contact with oxygen when left in the grinder, so, am I going to get the best out of a more expensive machine when the bean will not be 100%? and back to my milk question, will I destroy a nice shot by mixing it with tons of milk?
Yeah the Lelit Victoria would be great. You have a Sunbeam EM4800 at the moment? If you’re managing with an EM4800 which is a very basic machine you’ll find the step up to something like the Lelit to be pretty amazing. The only extra care and maintenance it needs is regular backflushing which is pretty easy. Where are you based? Are you able to get in to Jetblack or another store to have a look at the Lelit or some other options? I’ve always found actually looking at the machines and testing them if possible to be really valuable.Originally posted by braddo View PostOK looking at Lelit Victoria. Small footprint, auto refill, can make multiple drinks, 58mm basket, PID? and timer which is more handy than the clock on the wall (used as a guide only I like to watch the shot). So more features and more care free than the cheaper machines. Thoughts? Am I on the right track here?
It's a great machine mate, and if it suits your budget then you are going to have the potential to be in a world of wonderful coffee, for a long, long time...
Agree with Charlie...
If I ever felt the need to venture back into espresso machine territory, that's the sort of machine I'd be going for too...
For two double shot lattes a day, a single boiler will be fine.
charlie
OK this is good info everyone thanks. Have seen your site Charlie but misses the pre loved page, so I will be looking at that too. Thanks all for their time. I will buy a machine when I get through the maze.
My afternoon procedure-
Heat machine
Pour shot
Steam milk
Clean wand and let steam out
Run water through the machine like pouring a shot will no pf in it
Drink coffee
Come back in 20-30 mins
Make another coffee as above
Turn off machine
Will a single boiler meet my needs? BTW I do have a Eureka grinder.
I will start doing some homework with the above info, don't want to bother you all too much.
Hi braddo and welcome.
The 41LEM is a solid little machine that seems like it will meet your requirements. The 41TEMD is the PID'd version and for not many more $$ you get more temperature stability, a clear readout of temperature, the ability to tinker with temperature and stronger, more consistent steam. So well worth the upgrade in IMHO. The 57mm double filter baskets on these machines hold 18/19g so plenty for a double shot.
The other single boiler in the Lelit range is the newer Victoria. This has auto fill on the boiler which means it can steam all day long and then it will automatically refill itself after steaming. This would suit someone who makes more milk coffees. We also have a good collection of second hand coffee machines available which might suit you.
charlie
I've got the PL41. No PID, as it wasn't an option at the time. I don't find the 60s or so wait to get to steaming temperature much of an issue. Biggest difference I found over the thermoblock machines is the steam pressure is a lot better with the boiler.
I need case it helps most people say that milk based drinks on a single boiler machine is a pain as you have to wait to heat and cool between pulling shots and steaming milk. You also have a risk of not filling the boiler and cooking the element but I think Lelit have a machine with auto fill.
if you want to pull shots and steam milk at same time you’ll need to step up to a HX or stay with the twin theromblock design you have. The other option is dual boiler but these are generally more expensive unless you go to a appliance level brand such as bedeville.
keep in mind if your after longevity you’ll need to get a water filter system set up to treat you water properly to avoid scale build up so account for that. Also don’t forget the importance of a decent grinder as a great machine is only a good as the ground beans you put through it (very generalised but hope you get the idea).
a good and well loooked after second hand HX at a guess $1000-1500 but recommend you fit an OPV to that) and a grinder for $300 odd and you’ll well sorted. Just depends on what you want and how far the budget goes
I had a Nuova Simonelli Oscar 2 with an OPV fitted extra that would be around $1600 new (guess $900 second hand) and a Lido E ($200 2nd hand-$300new) hand grinder and that made really good coffee.
Hope I’ve helped. Oh did I meantion start home roasting to ‘save’ money hahaha
I seem to go OK with what I have, but I am an amateur. I brew the coffee first, then steam the milk, and I'm happy to do that it turns out quite good I think, well I am satisfied with it anyway. Is this what you would describe as a 'messy' procedure? Happy to take advice. Will look into HX but i do have limited bench space.Originally posted by BobSac View PostLelitPL41 is a single boiler right?
If milk coffee is your thing and you want no messy procedures, HX is my recommendation.
It's going to be $1800+ though, not $900
Is there no easy way out?
OK not too many options being made here, so I will look into Pretzal's suggestion, and if anything grab a LelitPL41 with PID so I have temp and pressure redings. I think it's a safe option for what I need.
Braddo if you decide on the Lelit get the PID version, not much more, aids consistency and much cheaper than adding later. Think it is PL41TEMD
