Good afternoon, I recently replaced the seal kit on my La Pavoni Europiccola (post-millennium) machine and have noticed that the element plate (and o-ring) does not seal well against the brass boiler fixing ring. The plate appears to contact brass boiler fixing ring before compressing the seal. When I went to water test, it leaked out the bottom.
Perturbed I reviewed some 'before' pictures I took of the machine and noticed that the top gasket was not present. During the seal replacement I fitted both gaskets per the design intent. Does everyone else have two gaskets?
The gaskets are #701806 in the link below;
https://www.coffeeparts.com.au/pavon...olo-main-parts
I feel that the brass boiler fixing ring needs to rotate around further to allow the element plate to press down deeper to the o-ring. It is already around pretty tight, with lubricant as well.
I've just had the base powder coated and the guy said that the coating won't stand high temps, which is why I had so much damage before. If I leave one of the gaskets out, I'm worried this will happen again.
Thoughts?
Paul
Thoughts?
Paul
