EM480 setting for 6910?
  • EM480 setting for 6910?
    Good evening!!
    My 480 has finally arrived and I remember seeing some comments a month or so ago re the normal setting people use for their 6910s?
    What number should I start with as a rough guide?
    James
    Re: EM480 setting for 6910?
    The instruction manual says 12 - 16.
    Ive been using 13 this week.
      See the threads about 0480 mods if its grinding too course or fine .. which may well be the case..
        I set it to 18. As i found there is nothing coming out from the spout if i set the setting less than 18. I dont know y. But i can get a really gd shot for 18.
          Sugilun, That doesnt sound right to me, irrespective of the number [12, 15, 18 whatever] I found that a number either side would still produce a shot [albeit about 9 sec, too slow or too fast] and I found I would usually have to go at least two steps finer from optimum, before Id choke the shot.
          I have a different machine though, so I guess the pressures may differ.
          As TG said, the manual states a range of 12-16, others here found 6-8.
          Just set it up for a 30ml single or 60ml double pour in about 25-30 sec.
          The volume & time is only really a guide since you want to stop the shot at the onset of blonding.
            Ive recently had to drop mine to zero. I think there could be a prob. On the 6910, I over-extract to about the 3 oclock position on the gauge. I have to really put a lot of pressure into my tamps too
