Clear Water Dripping around Portafilter
  • Clear Water Dripping around Portafilter
    Hi All,
    Recently my Silvia has started leaking clean water from (I guess) around the grouphead seal when I try to pull a shot.
    Background information...my Silvia was away for repairs for a week (nothing to do with grouphead) and I bought a bottomless portafilter as a welcome home present for her. On her arrival home, I also thought it must be time for me to clean the shower screen for the first time (She’s about 4 months old) so I unscrewed it (without any screwdriver mishaps; couldve done it with my fingers), soaked the parts in cafetto and put them back properly (finger tight screw).
    Then I turned her on, let her warm up and had a go with the bottomless portafilter. The shot looked pretty OK but there was clear water running down the handle and sides of the porterfilter. It was a pretty low dose and I didnt choke it or anything. I then tried with the normal basket and also got the same normal looking shot in the cup and a small amount of clean water dripping out (something that had never happened before). I pulled the screen etc back out, double checked things and screwed them back in; all seemed fine.
    I had a search through coffeesnobs and thought that I might need to put a bit more muscle into it, which I did, and the water stopped dripping out with the normal portafilter (strange because I’d always locked it in fairly loosely (i.e. not heaps tight) and had never got leaking before) but I still get a bit of dripping with the bottomless portafilter (drip, drip, drip from where the handle meets the body of the portafilter) even when I’ve locked it in very tightly.
    Also, I’ve noticed that while I’m running water through the group to warm things up, water often stops coming out for a few seconds before resuming again. I *think* I’ve seen this before, but I think it seems to happen a bit more frequently in the last few days...or i might be imagining the increased frequency.
    Also, my husband used Silvia this morning and when I got around to using her, the filterbasket seemed to have ‘stuck’ to the grouphead seal (it hasn’t happened before). I think he locked it in too tight after using it but then I thought that it might be because there’s something strange happening with the seal…
    1) Did I screw something up when I put the screen and parts back?
    2) Could something have been damaged while in transit/being fixed…I don’t think this is likely because I’m pretty sure Silvia didn’t go to the likes of northshore hospital!
    3) Should I replace the seal? It’s pretty new and I haven’t been too rough with it.
    Any advice?
    Thanks Guys!
    Re: Clear Water Dripping around Portafilter
    Cant help you, my Silvia leaks water if I overfill portafilter with coffee. I will keep eye on this post with interest in case it ever happens to me down the track...............cheers Greenman
      Just re-read my post and i should have written portafilter instead of basket in the paragraph (amended) below
      "Then I turned her on, let her warm up and had a go with the bottomless portafilter.  The shot looked pretty OK but there was clear water running down the handle and sides of the porterfilter.  It was a pretty low dose and I didnt choke it or anything.  I then tried with the normal portafilter and also got the same normal looking shot in the cup and a small amount of clean water dripping out (something that had never happened before).  I pulled the screen etc back out, double checked things and screwed them back in; all seemed fine."
      Thanks Greenman...has this happened to anyone out there?
        Hi Sammy,
        I think your seal should be fine. you may have tightened the screw in the shower screen too much. This happened to me on an old breville machine. I removed the shower screen to clean it and found that it leaked water around the top of the group after i screwed it back in.
        I released the screw a little and found that this solved the problem. tightening the screw too much seemed to compress the seal up under the screen leaving more space between the filter basket and the seal.
        Rancilio also mention this on their Silvia website: "When reinstalling the dispersion screen, be sure to install the dispersion disk correctly. Do not overtighten the screw"
        Hopefully this helps
          I cant really help you with the cause of the dripping water, however I believe that reason for not over tightening the shower screen screw is so that you can undo it next time. I dont see any way that the shower screen or water dispersal can be put back the wrong way - it just wouldnt work. You dont say what work was done on your Silvia, the dripping can happen after changing a seal, while it beds in. Ordinarily though, I would think that 4 months was too soon to be changing it, though someone more knowledgable may have a different opinion. Does the portafilter lock in to the same position? Can you tighten it a bit further?
            Hey guys
            Thanks for that info...the dripping water isnt really that much of a problem in itself (though id prefer if it didnt do it), but im just a bit worried that it indicates something else is wrong. Hopefully not!
            I agree Viviane; I definitely put the screen back the correct way (very very easy) and made sure i didnt do the screw up too tightly because ive heard warnings of it getting stuck there down the track if done up too tightly (thanks for the info matta i hadnt heard that before, i might try loosening it a bit tomorrow morning and see if that changes anything...though its pretty loose already). The Silvia had some rust taken out of the frame last week, so nothing near the group head.
            I think the normal porterfilter drips when i lock it into the same position so i now need to tighten it further to stop it dripping. I tighten the bottomless one as much as i can and i still get dripping.
            Hmmm...
              Sammy, intermittent driping is usually caused by an overloaded basket.
              On older machines, permanent dripping is almost certainly caused by improper sealing between the the rim of the basket and the group seal.
              After four months of normal use though, your group seal should still be in pristinine condition.
              Id check the rims to make sure they are smooth -- they should be. A new seal should fix the problem.
              Otherwise, check the overpressure valve-- it might be pumping out way above the 9-10 bar through the group instead of diverting water back into the tank.
              Your practice of NOT overtightening the screen screw is good -- they need only minimal torque and no encouragement to stay on fast!
              Also, portafilters dont need to be overtightened either-- from memory, the 7 oclock position was about right, at least on my ex.
                Im with robusto, definitely sounds like a bad group seal/gasket.
                You could try replacing it with a commercial rancilio group gasket, the same size but apparently firmer that the silvia one (according to espressoparts.coms description)
                  Thanks for that info guys!
                  Robusto, what do you mean by intermittent vs permanent dripping??? I intentionally underfilled the FB this morning and pulled an underextracted shot (60ml in about 19sec) with the PF locked tightly into the 5oclock position and i still got the dripping (it ran down the side of the PF where the body met the handle of the PF)...this would mean its not dripping from being overloaded wouldnt it. From memory I think i used to lock the normal PF into about 6 or 7oclock position...But i didnt really think about it, i just pulled it into position.
                  Ive also noticed that water seems to be dripping out of the steam wand more than it used to normally do and water is also dripping out of the 3-way valve into the drip tray as the machine heats up (i just flicked Silvia on and happened to look at the drip tray and noticed that); ive never looked before so that may be a normal thing. The dripping slowed down as the machine heated up. Ive never scrutinised it this much so it could be normal but do these things indicate that the machine is operating at a higher pressure than it normally did? I havent touched the OPV; could transportation or anything like that make it self-adjust? How do you test the pressure?
                  Im not sure what the group seal is supposed to be like but its smooth, firm and rubbery with a slight circumferential indentation of the FB. Seems in pretty good nick to me (but i have nothing to judge it agains). I dont really want to replace it if its not the problem, but i guess if nothing else can be figured out i might have to do that.
                    This is normal and occurs to me on occasion as well with the Silvia. Usually, after turning it back on after its gone cold and Ive taken the portafilter out of the grouphead but left the filter basket stuck up on the group! Its no big deal, IMO.
                      Sammy, portafilter at 5 oclock position to me spells one thing: under-size seal. Its too thin. And obviously not sealing. That would be either because it is severely worn or the wrong size to start with.
                      Silvia seals have a chamfered or bevel edge -- make sure that faces the group, not the basket.
                      The other problems you mention, dripping 3-way valve, steam wand....are you sure the machine is only 4 months old? And that no-one has tinkered with it?
                        Thanks Scoota; i thought i read somewhere that it was bad to do this to the seal because over time it might wreck the seal. Dunno. Oh well its only the 1st time its happened.
                        Robusto, Im pretty sure the machine is an infant; i bought it brand new from a site sponsor a few months ago. The only time its left my sight has been before i bought it and when it was in for repairs last week (under warranty with the official guys doing the work)...im sure they wouldnt do anything like that without me knowing...I hope!!!
                        In terms of the seal, I had another look yesterday, took the showerscreen off again and took some photos of the seal. What do you think?
                          Sammy
                          My machine is about 4 years old and still has the original seal and its still going strong.
                          I get the occasional leak, if I leave it too long between backflushing with espresso cleaner [I try to do this every 2nd week and daily without chemicals].
                          The buildup of oils/gunk has an effect on the quality of the seal.
                          Once cleaned, it seals beautifully again.
                          Also make sure you wipe the lip of the PF before insertion.
                          FWIW, mine is fully locked and sealed in a 6:10 position [ie just to the left of the centre] but bear in mind all machines/seals/PFs will be different.
                          I agree with robusto, it sounds like the group seal is thinner, hence you need to  twist more anticlockwise to lock in the PF.
                          Hmmm...
                          Well, if it used to seal ok [with the original PF] then I reckon either one of two things has occured:
                          1)     The group seal was changed during the service/repair and its thinner than before.
                          2)     The "NEW" naked PF has a a different lip  to the original and therefore it is probably distorting the group seal, in which case after a little time it should settle.
                          The seal looks like umm err a seal,  its hard to tell, there may be many generic types available, but it looks like mine.
                          It does have some gunk on it, and I believe this may be enough to cause a leak.
                          Putting this as gently as possible, from that photo it looks like  the group is pretty dirty, it should look like shiny brass, so Im guessing that you need to backflush with chemicals more frequently and this should also assist with the leaking problem.
                          Also, after every session do the "PF Wiggle" ie run water through group and wiggle the PF around to help clean it. You can also put a wet "chux" on top of the PF, insert it and do the wiggle.
                          The leaking 3way valve may be another problem, but 1 thing at the time.
                          Good luck, keep us posted.
                            Sammy, just make sure that the machine is well warmed up before you take out the portafilter and it shouldnt be a problem. You want it all nice and warm anyway to get the best shot. I found that it really only happens when the machine is cold and so is the group and seal.
                              Hi Guys,
                              Thanks Scoota.  The Silvia is usually on for about 45min before I use it so I’m not sure why it stuck on that day.  Hasnt happened since though so thats good.
                              I talked to the guy who did the repairs and he reckons he didnt do anything apart from the rust.  He suggested that maybe Ive got some scale built up on the seal so its not sealing properly.  Does that sound like it could be correct?  What does scale look like? Should I be using filtered water in Silvia?  Should I descale her often? How?
                              Reubster that photo is a bit underexposed (looked a bit more shiny in real life) but I agree it needed a clean!  I pulled the showerscrean off again and gave all the little nooks and crannies a good scrub clean.  There was quite a bit of coffee powder gunk up in the grooves.  I cant get the brass shiny though; its still got those brown stains all over it (see the yellow ‘dot’ on the photo).  It’s also got white chalky marks on it like in the groove to the left of the green dot (though this might be cafetto that has dried on) and to the right of the green dot (these one’s aren’t cafetto and they wouldn’t come off).  Are they scale?
                              Also one of the bits that come off with the showerscreen wont go shiny either.  Is this scale? (see the area around the blue dot as opposed to the purple dots).  There is also this dint thing (below the purple dot) – is that normal? I haven’t dropped it or anything.
                              Ok…sorry for the ‘dots’!
                              In terms of the ‘dripping’ I put the old FB into my new PF and there is much less dripping.  I still get dripping occasionally though.  So maybe Reubster’s point 2 explains part of the problem, thanks Reubster!  The clean helped things too I think.
                              Um, so I’m not sure if it’s exactly “problem solved” but I’ll keep an eye on things.
                              Thanks Guys!
