EM6910 - single basket good, double bad
  • EM6910 - single basket good, double bad
    Hi, hope you guys can help me!
    Ive had my 6910 since last fathers day and got the free grinder with it. I generally drink doubles so regularly use the double basket. Over a period of time Ive had to slowly ramp down the grind number to try and get good pressure and a decent shot. I currently run it on about 4 and its still giving me crema-less shots! Ive removed the black thingy in the head in desparation and had no change. Then I thought Id give the single shot basket a go and got a really nice shot! Ive cleaned out the grinder but no improvement... Can anyone help please?
    Thanks,
    John
    Re: EM6910 - single basket good, double bad
    What is the make and model of the free grinder?
      It says Sunbeam EM0480 on the booklet
        Are you using the pressurised or non-pressurised baskets?
          i had the same issue, but realised it was just the grinder was crap - i have to run my grinder on say 4 to get my right shot in the double basket. (i NEVER use single anymore). With fresh beans, right grind and tamp, you WILL get good crema trust me.
            not sure about what theyre called, but Im using the ones for when grinding my own coffee (I can see through the holes) - not the ones with the extra floor.
            cheers,
            John
              Yes, even on 4 I dont get a good shot. I rang the Sunbeam supportline who mentioned that they had some customers having issues with the grinder (having to use a really low grind number) and the guy that developed the coffee machine has had a look and recommended using some washers between the burrs? Anyway they are sending me some washers (and some instructions I hope) so Ill see how it goes.
              cheers,
              John
                cheers,
                John
                Thats fine, youre using the right ones then. Be interested to see if the grinder mod helps.
                  Got the washers from Sunbeam today - wont be able to install till the weekend so will report back then.
                    Ive installed a washer and this has now fixed the problem! ;D
                      Excellent!
                        So instead of 4, what setting are you on now that youve installed the washers? Cos Ive got mine on 4 and Im not sure if its a machine issue.
