Re: JAMMED SILVIA SHOWER SCREEN
Woohoo! Success...thanks for the tips guys....
At risk of stating the bleeding obvious (Ive been caught out here, so I can), dont try to remove the screw while the machine is cold - that will seize any coffee oils hanging around. Also, try backflushing (with chemical) to remove said oils. A lot cheaper than bending your shower screen. I also keep a babys pusher (toddlers use them instead of knives) to unscrew - it gives you a lot more leverage.
Hope these help.
And once youve done that, change the screw head to something flatter and one that can be taken off with a regular screwdriver (not a socket).
hi phatboy
sometimes the only way to remove a flat shower is to bend both sides of the shower downward. this forms a u shape and holds the screw, then turn the shower in an anti clockwise direction(looking upwards) this will loosen the screw.
sometimes you need to use vice grips to grip the shower to be able to turn it.
replace shower and screw if damaged
do not tighten the screw, only nip up and then backoff 1/8 turn
graham
Righty-tighty, Loosey-lefty!!!!!!
thanks so much guys...will try the freeze spray stuff...
it is so stuck its ridiculas....and made worse by the fact ive been going clockwise due to the Coffee Company saying so, he reckons he went to check and make sure on his display machine...
Gday PB,
Cremakid is correct, looking in the direction of the application of pressure you need to try and turn the screw/nut in the anti-clockwise direction. If this is what you have actually been doing and the screw/nut will still not budge, you may have to see if you can grab a can of "Freeze Spray" (like this stuff) and direct this at the centre of the screw/nut in order to try and shrink it away from the thread in the Group.
When you go to replace the screw/nut, you need to make sure that you tighten it to "finger-tight" only, no tighter than this. Otherwise, the heating and cooling cycles of the Group will tend to seize the thread once again and you will be back into the same situation once more.
All the best mate,
Yep, anti-clockwise, looking up at the screw head from below that is (which would be clockwise if looking down from on top). Same direction that you turn any normal screw.
regards,
Bill
Guest repliedRe: JAMMED SILVIA SHOWER SCREEN
It should screw out anticlockwise, Try using an 8mm socket instead of the screwdriver.
Hi guys the shower screen on my silvia is jammed. changed the rubber seal which was easy but cant get the screen out.
PLEASE HELP!!! I rang Coffee Company and they said its clockwise to take the screw out :-?
Is this correct? a did try anti clockwise at the beggining....i slowly destroying the screw head thoughTags: None
