Breville Ikon or Sunbeam 6910?
  • Breville Ikon or Sunbeam 6910?
    Hi, i am new to this, and looking for a new coffee maker. I have read all the threads. Which of the above do you advise and why
    thanks
    Re: Breville Ikon or Sunbeam 6910?
    Hey bukkie, welcome to coffeesnobs!
    Both machines are relatively capable low-end machines - compared to the standard, single-thermoblock Sunbeams and Brevilles.
    Which you should get probably depends on your budget. Assuming you dont already have a decent burr grinder, youll need to allow a minimum of $150 for this (for the Sunbeam EM0350) - but this is the absolute minimum.
    The grinder is far more important than the machine, so I suspect youd be better off bumping up the grinder allowance by $350 and going for the Ikon and a better grinder.
    On the other hand, if you already have a good grinder - or can afford to buy one and still pay $700 for the Sunbeam - its a good machine with some distinct benefits over the single-boiler Breville (the ability to steam milk and extract espresso simultaneously for example).
    Either way, it would also be a good idea to consider saving up for a bit longer and getting a real machine rather than something made in China. It will cost more, but probably outlast 10 BrevilleBeams, all the while making better coffee
    Good luck with your decision!
    Matt
      Thanks, what do you advise as a real machine then?
        What M@ meant by a REAL machine would probably be a boiler style commercial built machine with minimal electronics.
        Something along the lines of a Silvia will be in your budget.
        However, as mentioned, a grinder should be your first priority.
