Hi All
A few months ago the breville started tripping the circuit breaker and I noticed stream escaping from the back of the warming tray.
After some research it looked like an O ring issue so I took the top off and found white deposits and some residual water. When I turned the machine back on I could see water coming from one of the sensor probes in the steam boiler and another leak from a water line to the stream boiler.
I have replaced both O rings, the sensor probe is now fine but the other continues to leak.
It currently has the metal washer and the red O ring but I've tried different combinations of just the O ring, 2 O rings and no washer, 2 O rings and the washer, 2 O rings and 2 washers but still it leaks.
Any ideas on how to fix this?
BTW the machine is about 4 years old
Regards
John
Regards
John
