EM 6910 - no water is coming from the shower or hot water but steam wand working
  • EM 6910 - no water is coming from the shower or hot water but steam wand working
    Hi
    I am new to the forum.
    I have bought a second hand EM6910 that has been never used for over 3 years.
    I fired it up and I can see that machine turns on alright. After some time all the lights go on indicating that the machine is ready. However, when the manual or single/double shot buttons are pressed there is no water coming out of the showerhead. There was very little water coming out only a few drops but not what is expected from the showerhead. This is the same for the hot water spout. On the other hand, the steam wand appears to be working well.
    Based on some reading on this forum, I turned on both the steam and the hot water together, but nothing changed.
    I have done a few videos to demonstrate this problem.
    https://youtu.be/_51i6n4P31o
    https://youtu.be/b0h8xW02w_4
    https://youtu.be/VpLQueTmH2M
    https://youtu.be/kZ9no3AVANA
    Will very much appreciate any help to fix this problem.
    Angelo
    Sounds like it's running dry, how long did you run the hot water tap for at any one time? Could require manual priming of the lines...
      Hi
      Thank you very much for your response.
      Hot water tap - maybe 2-3 minutes
      Brewing switch - may be up to 5 minutes
      How do I manually prime the lines?
      Kind regards
      Angelo
        Manually priming the lines is something a technician would do by disconnecting the hoses before and after the pump and filling them with water before reconnecting them. All with the machine unplugged of course.
          Thanks very much.
          I turned on both the hot water and the steam wand again. After about 3 minutes the machine turned itself off. The steam wand works powerfully, but the hot water did not (only a few drops). I could turn the machine on again after that. However the problem persists.
          With regards to the machine running dry (please excuse me for my ignorance), would the steam wand work if there was no water in the machine?
          Priming the machine...
          I am handy and happy to do it myself if someone can tell me how to manually prime the machine.
            Syringe full of water up the feed line to the pump.
            May need to have hot water tap turned on so water can exit.
            Maybe machine is blocked up, so might need a vinegar solution injected. Or descaler...
              Thanks.
              Where would I find the feed line to the pump?
                You will find a manual in the documentation sub forum, go to mid range machines then sub forums. You will find lots there that will lead you through the fixes.
                First thing to check is the pump, do you hear the pump operating when you hit the brew button? You can hear the steam pump when you operate that, you should also hear the brew pump when you operate that. Most machines do not need priming, they are designed to self prime.
                  Just watched your videos, the pump is operating, sorry, I should have viewed them before commenting. Have a look at the repair manual and remove the covers, you will be able to see the water route and identify the problem. There is a video somewhere on the site that describes getting the covers off but I cannot find it.
                    Thank you for your responses.
                    I have found a few manuals on the documentation section. Might try and open the machine up this weekend.
                    Will keep the post updated on my progress
                      Hi
                      I have managed to remove the back panels of the machine.
                      Cant really make much sense of the tubing yet.
                      I have posted video after turning on the machine with the back removed
                      https://youtu.be/ZOUhY8x-FjY
                      I need some advice about the next step.
                      I note that the tubing leading upwards from the moving water level is empty I think this may be going into the espresso pump. Thus, the pump is running dry as suggested by the great members previously.
                      What should I do? where should I injecting the vinegar / water solution?
                      Angelo Click image for larger version
ID:	848587 Click image for larger version
ID:	848586 Click image for larger version
                        If it's priming you are trying to do, then the hose coming off the bottom of the red pump is for the brew head. You can also undo metal nut on top of the pump to force water through the hot water wand.
                        Have you take the shower screen off as well to check that's all clean?
                          Well, I am not sure what exactly i am trying to do.....
                          I want the machine to work. The brew head and the hot water to work.
                          Is priming forcing water through the machine? Which tubes should I use for that ..... before Ukla motor or after Ukla motor.
                          Here is the set up I have done using a pressure can from bunnings. Could not find big syringes to do the job. I have been pumping for dear Click image for larger version
ID:	848669 Click image for larger version
ID:	848670 Click image for larger version
ID:	848671 life, but have not been able to force any water through the hot water spout or brew head. I even turned on the machine with the hot water tab open.
                          Stuck
                          Please help
                            Priming means filling with water, not forcing anything through. Might be best left to someone who knows what they're doing.
                              Thanks.
                              Now that I have opened the machine, I would like to try and do it myself. Got it second hand and keen to get it going without having to pay for a technician. While I am sure a technician will do a great job, would prefer to do it myself.
