I now have the machine upside down hoping to dry out the steam boiler in hopes that the cotton bud will dry out and fall back down towards the (inverted) access holes. I could cry!! Any advice/suggestions?
Gah! dropped cotton bud into steam boiler on BES 900 after successful descale!
Originally posted by Jackster View Post.
Keep it inverted and run a small hose into boiler, rinse and maybe will wash bud out
Originally posted by latte1978 View Post
Already tried floating it out - great idea about inversion and washout - will try that too! Have ordered an led probe camera that has a small enough diameter to fit in - should help if necessary (surprisingly only $15)
Another idea - you may be able to suck it up with a piece of clear pvc tubing attached to a vacuum cleaner hose. It should be able to hold onto it if it gets close enough. Just make sure there is no water left in the boiler first or it may not improve the vacuum cleaner!
Thanks all for your input hereI ended up spending $13 on ebay to get a 5.5mm probe camera, hooked it up to my laptop, located the little bugger and used two bent fire sparkler ends to nab it and pull it out. Phew!
Put it all back together and it's worked for the last month but every so often it would have the same problem that our friends' did a few years ago - heats only to approx 70 degrees. I have reverted back to the EM6910 for a bit as I'm busy at work for the next few weeks and I don't want to take it apart again. When I took our friends' machine apart - all I did was prime the piping again, but if that doesn't work on ours? Any ideas? I'm about to go through the old threads as I'm sure another CS would have something on this! Is this the steam pump or the water pump? Does the machine even have both??!!
Originally posted by Jackster View PostMaybe vacuum breaker is sticking, giving false boiler pressure so turning pressurestat off too early
