Just received my nice new group handle from Sunbeam. Even got a business card from "Poppy", so I know who to thank!
Brewed my first cup in a week. Sooooo nice! ;D
Noticed while I was cleaning the machine this time that my seal needed replacing, getting quite deep grooves in it. Not bad I suppose for 17 months, but Ill get onto it before it splits.
AM, Id love to get a new handle on my old portafilter. I assume that whats left stuck in the hole is a threaded brass fitting. So if I drill it out I can just screw one of the handles from coffeeparts onto it? :-?
BTW, I noticed from one of your other posts on 6910 collars that you speak of how far the handle needs to be turned to lock it. At the moment, with a full single filter basket fitted (coffee up to 5mm from rim as per Sunbeam instructions) I turn it to about 5:00 to lock. However, when I put an empty double basket in with the plastic blind to do a backflush I have to twist to 4:00 to lock. Is this likely a collar problem? :-/
Originally posted by 7549544F454453464E45210 link=1215333715/32#32 date=1289962497
You have to compare apples with apples.
Yeah, sorry, re-read that & it sounded dim. :-[
The empty single basket doesnt go as far to lock as the double, but more than when full. Lets say 5:30 to be pedantic. Short of dismantling the unit, are there any other tell-tale signs I should be looking for???
Originally posted by 1824392228293E2B23284C0 link=1215333715/34#34 date=1289967287
Look at the inside of the collar and see if you can see signs of the track wearing.
Well, there are a few scratches. Its a bit difficult to see really. I took some photos, but they dont really show enough. Should I be seeing brass if the collar is worn? Or should the tracks look uneven?
Do some extra searching and there are plenty of pics of said - WORN collars. Think there might be a few in the "EM6910 Collar Replacement "pdf that talks about changing said collar as well.
