BES920 Breville pressure where did it go
  • BES920 Breville pressure where did it go
    Breville double boiler 5 years old, left it unused about 9 months, tried to make a cup and the pressure is now too small to push through grinds.
    Pls would like to know, have I made a mistaken by letting it sit unused, and can this be repaired and is it worth it.
    Estimate this machine has made only around 300-400 extractions in total.
    I only used it here and there, but then as said left unused for a longer period. (Why did I have a feeling this would happen?)
    thanks,
    Do you get decent flow through the group without a PF ? Could be the pump piston / valves a bit sticky/stuck from sitting around? Could just be scale / blockage at the solenoid. The water holes are tiny. What pressure do you get if you use the blind? Cheers
      Could also be the OPV. They're cheap to replace. If it's the OPV there will be water being sent back into the water tank while you're pulling a shot, you can tell this is the case if the surface of the water in the window at the front of the tank is rippling.
